jonny-5 0 Posted July 30, 2005 Hi, The power steering on my corrado is VERY noisy, sounds like it's straining or something and groans alot. The belt is ok but does squeek on full lock. Is the pump shot? Thanks for any help Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 30, 2005 You've checked the fluid i take it? - should be green also! Quote Share this post Link to post Share on other sites
jonny-5 0 Posted July 30, 2005 Yeh done that, got a feeling the previous owner used the other stuff tho, i might try draining the fluid and replacing it with the green stuff just to be sure. Quote Share this post Link to post Share on other sites
jonny-5 0 Posted August 5, 2005 Just changed the fluid - twas very dark green, now it' sgot some nice new stuff in it, i bled the system aswell and it seems to have sorted the problem. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 5, 2005 h6bgm, good to hear it... Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted August 5, 2005 On the subject of steering fluid, whats the best stuff to use? Quote Share this post Link to post Share on other sites
coolrado 0 Posted August 5, 2005 and whats the bleeding/re-filling procedure? Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted August 5, 2005 The best and ONLY stuff to use is that specified by the dealer and now sold by ECP and poss a few others, it is different to the normal swag and i've know a number of pumps that have suffered because of wrong fluid. Often if it's noisy because of wrong fliud it won't recover as the seals/bearings have been damaged Chris Quote Share this post Link to post Share on other sites
jonny-5 0 Posted August 5, 2005 i ordered mine from GSF, about 5 quid a bottle and you only need about half of it. To bleed the system just raise the front of the vehicle and unscrew the cap off the pas reservoir thingy and do loads of lock to lock turns and just keep the reservoir topped up as your doing it. Quote Share this post Link to post Share on other sites
JBOB 0 Posted August 15, 2005 I need to resurrect this thread :lol: May sound really silly but how do you drain the fluid and make sure its all out?? Mine is really dark :( Quote Share this post Link to post Share on other sites
veritas137 0 Posted August 20, 2005 Yeah, I'd like to know the procedure for draining also. My rack has a slight leak and the previous owner used non oem stuff to fill it. Going to pick up a fresh bottle of fluid next week and would like to do this sooner than later since my pump is starting to make some bad noises in the morning. Quote Share this post Link to post Share on other sites
jonny-5 0 Posted September 11, 2005 To drain it there is a pipe connected to the pump it's self that is just secured with a jubilee clip, just undo that and do some more lock to locks to squeeze out the fluid Quote Share this post Link to post Share on other sites
cubed 0 Posted September 18, 2005 well its seems my power steering has given up completely! its weird! its difficult to turn right then just seems to release then its ok, but this mornin it didnt want to play at all!!! im stumped cos i know the sum total of zero about pas,so any advice is welcome!!! ta! Quote Share this post Link to post Share on other sites
jonny-5 0 Posted September 18, 2005 Try changing the fluid like it did and check the condition of the belt and the tension on it. Quote Share this post Link to post Share on other sites
cubed 0 Posted September 18, 2005 already changed the belt so i,l get some fluid when i get my top mounts tomorrow! cheers bud!!! Quote Share this post Link to post Share on other sites
derekl 0 Posted September 19, 2005 Hi, I have a strange problem with my power steering, it seems to turn off intermittently causing the steering to go very,very heavy. It happens sometimes and then turns back on again?? Any ideas are welcome. I don't have the corrado that long and need to get it fixed. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 20, 2005 Check the fluid level and also the colour (should be green) Also check the belt s not slack.. Welcome to the forum btw! Quote Share this post Link to post Share on other sites
cubed 0 Posted September 20, 2005 just got the fluid at the same time as being sent two different top mounts! so just checking this is right its febi bilstein m 6162, please be right pleeeease! :brickwall: oh and heres a daft question!! engine runnin or not for drainin??,,, yeah i know! :oops: Quote Share this post Link to post Share on other sites
cubed 0 Posted September 21, 2005 ok done it and its made no difference whatsoever! seems to have trouble bleeding, unless that whooshin noise is just fluid! pas pumps goin isnt it! more money! just hope its not rack related! could pricey chasin this fault! oh and belts tight as a drum! need to sort it or me and the c could fall out!! :mad: Quote Share this post Link to post Share on other sites
