StormchargedVR6 0 Posted July 31, 2005 Anybody on here using porsche front brakes, looking for some advice. I can get hold of the mounting brackets, from a company in germany called MBT, i was told to go for the mono-block as the boxster. But what discs? im got 8x17 rims, so can't see a problem there. Quote Share this post Link to post Share on other sites
Dixxy 0 Posted July 31, 2005 A bit off subject i know but i upgraded to audi TT 312mm front brakes. These have transformed the car... now very sharp under braking. Just a thought prob a fraction of the price. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted July 31, 2005 i think phatvr6 is using a porsche brake set up Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted July 31, 2005 i was thinking of the TT set up, do the calipers fit straight on Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted July 31, 2005 i was thinking of the TT set up, do the calipers fit straight on i'd advise you to go the TT route as i doubt you'd get bremo's/porsche calipers behind RH ZW1's. I'm running big brakes but required a 30mm spacer. Flared arches made it possible. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted July 31, 2005 yep, I am also using boxster S calipers with the MBT brackets, the blank ones that you drill and machine to your own offsets. for discs I have 993 Carrera 4 turbo 323mm outers, on Audi TT fitment "MOV-IT" alloy bells. they sit a bit close to the hubs, but it's only on a tiny lug that doesn't actually do anything so I'm going to grind that off. I didn't want to use the VR^ disc offset as that would have sat the disc too far out into the wheel, I wanted the disc to be as far 'in' as possible so I had a greater choice of wheels that will clear the caliper. even so, I'm still going to have a thicker bell made up #9rather than run a space) to space the wheel out a further 3mm to cllear. I would sell yout he bells but I think i#ll use them on the rear if I can find a suitable disc size to use with the r32 rear calipers. I've be ding a full thread on my brake set up as and when I do it over the next month anyway so that should help you out loads if you're lokking into a similar setup. Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted July 31, 2005 cheers phatvr6, is there no porsche discs that will fit , you got to use custom bell, where can i get MOV-IT one from. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted July 31, 2005 the porsche bells are a mile off offset wise, they'll never go over the VR6 hubs, plus they will be for 5x130 fitment.... When I get my new bells machined up I'll ask the guy how much he wants to copy them to make a set up for you. I have some aerospace grade billet alloy i bought for some hub adapters years ago that never got used which is ideal for the job. actually, it's be easier if I sold you my Mov-it ones and had a matching pair made up for mine now I think about it. open to offers on them, includiing the disc too as they have tiny crack starting to show from the holes. genuine porsche items AFAIK. Quote Share this post Link to post Share on other sites
