VWci 0 Posted August 11, 2005 hi fellas, i wonder that how easy is using 16v head on 8v engines ? for instance, on 1.8 8v mk2s or 2.0 8v mk3s very easy, easy, not easy, difficult :D Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted August 11, 2005 i dont think the oil path ways line up, but i may be wrong,,, Quote Share this post Link to post Share on other sites
h100vw 0 Posted August 11, 2005 Difficult. Tell us the rest of the question, why do you want to know? GAvin Quote Share this post Link to post Share on other sites
dub envy 0 Posted August 11, 2005 i dont think the oil path ways line up, but i may be wrong,,, That's what I was going to say.. Quote Share this post Link to post Share on other sites
VWci 0 Posted August 11, 2005 So using 16v heads on G60s,mk2 8v gtis and mk3 8v gtis are difficult.... why am i asking? 16v G60 is the answer......;) Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 11, 2005 I've done it,fitted a 'kr' 16v head on a 'PG' block using the G60 pistons,horribly low C/R,but i was boosting nearly 2 bar turbo press...,is it difficult?,well that's quite a loaded question,how skilled are you?,what tools do you have access to? do you have a garage?,.... 1 thing is certain,the oil ways DO line up on the 'PG' block when using a 'KR' head,it's not the actual fitting,it's all the other small things that cause headscratching/swearing etc. Quote Share this post Link to post Share on other sites
flusted 0 Posted August 12, 2005 like not having a breather and needing cut outs in the psitons Quote Share this post Link to post Share on other sites
h100vw 0 Posted August 12, 2005 Far easier to fit low comp pistons in a KR/9A block. The 'normal' route to doing a 16VG60 as far as I am concerned is to start with a G60/PG and use a KR motor and go from there. A lot less parts to obtain. Put 16V G60 into google and lose a day or 2 reading. Gavin Quote Share this post Link to post Share on other sites
billinjah 0 Posted August 12, 2005 i may go with this route next year 270 bhp with boot loads of torque sounds good to me and bm sell kits that seem to take a lot of the headaches away. Quote Share this post Link to post Share on other sites
Yandards 0 Posted August 12, 2005 If you do billinjahg60 mnake sure get them to supply you with front mount alternator brackets. You will need a new alt as well though.. Quote Share this post Link to post Share on other sites
VWci 0 Posted August 12, 2005 Required 16V parts for G60 base engine: Custom BBM low compression 16V pistons for use in the G60 block 16V Cylinder head complete 16V Scirocco Intake manifold lower and upper 16V Distributor, complete 16V Distributor Block off plate complete 16V oil pump, complete 16V Secondary shaft and gears complete 16V Timing belt and gears, complete 16V Exhaust Manifold or 16V Header Required G60 parts for 16V base engine: G60 G-Lader Supercharger or BBM Screw Compressor Supercharger kit G60 G-Lader mounting brackets and belt tensioner complete G-Lader outlet (silencer box) or BBM RSR outlet kit G60 Serpentine / idler pulleys for water pump and alternator G60 AC pump or European water pump pulley G60 Throttle body, complete G60 Fuel Injectors and FPR G60 Idle stabilizer valve (ISV) G60 Digifant1 ECU and engine wire harness G60 Digifant control relay G60 Oxygen sensor G60 Water temperature sensor (blue) G60 CO% potentiometer G60 Relays, fuel pump G60 Intercooler, IC hoses to and from the G-Lader G60 Lower water pump pipe Upper and lower coolant hoses G60 Radiator and fan assembly http://www.bahnbrenner.com Quote Share this post Link to post Share on other sites
