fleur322
removing front bolt out of r/h wishbone
My car as just failed its MOT on the r/h rear wishbone bush :( . I am going to attempt change the wishbone my self, but noticed the the front bolt in the wishbone is really close to the sump. Do you need any specialist tools or is it a case of removing the sump? Cheers Linz
Err - what model do you have ??
Not sure about the VR but on 4 cyl models, there's no need to go anywhere near the sump when changing the front wishbones.
I did it with a 16mm spark plug socket and a 4 or 5 extensions. Real easy tho. Don't do what I did and assume it was just the little 13mm nut on top holding it together.
i did exactly the same,until i noticed the hexaganol head :lol:
Thankyou very much for all your help the job went very smoothly once I knew how. Not a bad job at all thanks again Fleur :D
