Blue_Joe 0 Posted August 28, 2005 As it says in the title the dipped beam has stopped working on my headlights. The sidelights, fogs and full beam all work fine. The fuses are fine, and I've tried a switch from a Mk2 Golf GTI and still had the same problem!!! Any ideas???? This is just typical Pre-show problems that always seem to occur a few days before due to going to a show!!! Quote Share this post Link to post Share on other sites
Riley 0 Posted August 28, 2005 did you check the bulbs m8? it can happen where two seperate filaments blow around the same time. or if you have an uprated loom,maybe the fuse in that has blown? neil. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted August 28, 2005 Hmmm true didn't check the fuse in the uprated loom! Didn;t check the filaments as didn't expect both to go at exactly the same time, especially when they are brand new a few weeks ago when I fitted the angel eyes Quote Share this post Link to post Share on other sites
Riley 0 Posted August 28, 2005 ahh,id guess at the uprated loom fuse then m8 as it feeds both low beams :wink: neil. Quote Share this post Link to post Share on other sites
Rob Heath 0 Posted August 29, 2005 Had a similar problem with mine, the main beam wouldnt work, enden up just bein the fuse in the uprated loom Quote Share this post Link to post Share on other sites
TREVR6 0 Posted August 29, 2005 Mine to but it was a relay on the uprated loom full of water. Quote Share this post Link to post Share on other sites
h100vw 0 Posted August 29, 2005 Anyone who has one of my looms and there are a few, can contact me anytime for help. I always give out my number with the looms, just give me a text. If I am free to talk, I'll call or text back. I might not be a big outlet but customer service is important to me. Even after 12 months if something dies, I am still here, well til I go to Australia. Lost my number then PM me. I am rarely away from a computer for more than half an hour, unless sleeping. @Blue_Joe are you sorted now? @Rob, did you fit the 30A fuse I send out for your main beam. @TREVR6 Was that one of my looms? I don't keep a list of who buys them.... I know I should. Gavin Quote Share this post Link to post Share on other sites
Riley 0 Posted August 29, 2005 while youre here m8,just like to say i fitted one of your looms a couple days ago(bought it ages ago!) and it gives a v noticeable improvement straight away! 8) only slight problem is the fuse holder,it keeps splitting and falling off so the positive has no connection. ill probably secure it with some tightly wrapped insulation tape. :) neil. Quote Share this post Link to post Share on other sites
Andy665 0 Posted August 29, 2005 Have you checked the relays and the dashboard switch - my lights started playing up, sometimes they'd work, other times they wouldn't, changed both relays and they are now fine Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted August 29, 2005 Sorted. Was jus a loose connection on the fuses on the uprated loom! All fixed Quote Share this post Link to post Share on other sites
h100vw 0 Posted August 29, 2005 Glad to hear it..... Gavin Quote Share this post Link to post Share on other sites
Rob Heath 0 Posted August 29, 2005 h100vw: Yes mate, I have put a 30 amp fuse in, but it is a tsr loom (Was already fitted to the car) Quote Share this post Link to post Share on other sites
