coolrado 0 Posted August 30, 2005 just got a new cambelt, tensioner and tappets which i need to get done before i drive down to ed38 on friday. i have removed the 4 allen bolts that hold the outer two pulleys onto the crank but they dont seem to want to come off in a hurry, how the heck does it come off? or am i not swearing at it enough? :lol: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 30, 2005 give it a tap side to side with a rubber mallet.. it will proberly have some built up corrosion around it but it will budge...with a tap Quote Share this post Link to post Share on other sites
coolrado 0 Posted August 30, 2005 cheers so is it just a face to face mounting then? i didnt know if i needed a puller or something ah well i will just have to get the scousers screwdriver out :lol: Quote Share this post Link to post Share on other sites
coolrado 0 Posted September 1, 2005 hmm i tried battering the crap out of it with a rubber mallet and it didnt want to shift at all so i borrowed a pulley puller from a neighbour which did the trick but it was surprisingly well stuck on. the cambelt didnt look too healthy when i got it off, it was very shiney and covered in fine cracks and according to the service history it should have another 20k left in it :shock: any ideas what torque settings i will need for the bottom pulley bolts, the water pump pulley bolts, the tensioner, and the camshaft caps? i seem to remember 15lbft for the camshaft caps but i cant remember the tightening sequence either :wink: Quote Share this post Link to post Share on other sites
Henny 0 Posted September 1, 2005 coolrado, get hold of a Golf haynes manual... the torques are the same as in there and it has the tightening sequence for cam caps and head bolts too... 8) Quote Share this post Link to post Share on other sites
coolrado 0 Posted September 1, 2005 i have actually got one but i let a friend borrow it and he is in eurodisney at the moment :roll: so they are all the same as an 8v gti ? i know a site which has them all listed for a golf so i will check that cheers Quote Share this post Link to post Share on other sites
Cougar 0 Posted September 1, 2005 Check out the serpentine belt tensioner install trick I posted a few minutes ago. Might save you some headache. Quote Share this post Link to post Share on other sites
