wcrado 0 Posted September 7, 2005 I've noticed several times in different places that often 2 types of KR Engine are listed, 1 with 132bhp and 1 with 137. Most notibly today when looking through an NGK spark plug application book.In fact in this instance they were listed as 133bhp and 139bhp. Whats the difference? i know one is fitted with a cat maybe, and the 50mm inlet manifold, but apart from that is there anything else? Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted September 7, 2005 early models (like mine) did not have a cat so have a couple of bhp more Quote Share this post Link to post Share on other sites
ben16v 0 Posted September 7, 2005 AFAIK the very early G and H came with 40mm inlet (with a stamped circle thing?!?!?! and little stripes on the 4 branches) later early golfs 50mm no cat cat until 2.0 ltr 16v `92 Quote Share this post Link to post Share on other sites
carpy25 0 Posted September 7, 2005 kr 1.8 16v fitted to mark 2 golf's is rated at 139 bhp same engine in the 1.8 corrado is rated 136 bhp vw put the loss of 3bhp down to manifold changes the kr with a cat fitted is known as the pl rated at 129 bhp all the info can be found on this site http://translate.google.com/translate?u ... uage_tools Rob :D Quote Share this post Link to post Share on other sites
Yandards 0 Posted September 8, 2005 There is one other difference between the Goof KR and the rado one, the flywheel on the rado is 228mm the goof is 212mm Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 8, 2005 There is one other difference between the Goof KR and the rado one, the flywheel on the rado is 228mm the goof is 212mm Won't make any difference to hp though, the golf exhaust system might, the back sections are not the same parts as the C. David. Quote Share this post Link to post Share on other sites
wcrado 0 Posted September 9, 2005 cheers. swapping my blown-up rado KR engine for one from a Golf so wanted to know what differences there would be. Bit concerned about this flywheel situation though, as obviously now i'm going to have a lighter flywheel so i'm guessing i'm gonna lose a bit of power up hills and stuff?? Quote Share this post Link to post Share on other sites
chrishill 0 Posted September 9, 2005 thats a gran-turismo misconception, having been in a vr with a vastly lightened flywheel i can assure you you wont notice the difference. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 9, 2005 cheers. swapping my blown-up rado KR engine for one from a Golf so wanted to know what differences there would be. Bit concerned about this flywheel situation though, as obviously now i'm going to have a lighter flywheel so i'm guessing i'm gonna lose a bit of power up hills and stuff?? You can't use the golf flywheel, you'll need the flywheel that matches the 02A cable change box in the C, the golf one is for the old rod change boxes. David. Quote Share this post Link to post Share on other sites
Yandards 0 Posted September 9, 2005 DW is right, you will need to take your old flywheel, clutch and clutch cover off of your knackered 'rado engine and fit to the 'new' golf engine. Luckily it is just a straight swap although you will need 6 x new bolts for the flywheel to crankshaft as they are a one shot item. Quote Share this post Link to post Share on other sites
