kebabman
Wheel size
Thanks guys, I've got a VR.
Looking at that link Chris posted, the 15" steels are ET38...but the 16" alloys are 42, weird. How will I know when I pick them up? Just fit them and see if they rub?
Can I get spacers to make ET42's fit?
you could probably ring a dealer and ask TBH!
whatever the offset they should still go on, they'll just rub, catch the arches or catch the struts! :lol: cant remember which way around offsets work (it is 5pm) so i'm not sure if you can space them... lower number sits closer to the hub? is that right?
lower number sits further out.
The reason that the 16" are different offset from the 15" is 'cos the widths are different too... ;)
If it's a 42mm offset, you can just lob in a 5mm spacer to make 'em ET38...
