mrbeige
"Short" Shocks?
Does anyone to a "short shock"? H&R? I'm sure I've seen feature cars in PVW and the like that have short shocks rather than coilovers to get the desired low stance. Would this avoid hitting the bump stops, as you expect from coilovers, as the shock is shorter?
i think if you look for 'uprated' dampers/shocks they should be shorter, or at least be able to cope with shorter springs better than the standard shocks can.
