Critical_Mass 10 Posted September 19, 2005 Ive had a 68mm pulley fitted along with an SNS chip, however i didnt really see any benefit, i was later told i d need to get it setup properly on a rolling road. Would resetting the ECU to adjsut to new chip and pulley help? If so hows this done, simply disconnecting the battery? Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 19, 2005 There is no reset for the G60 ECU mate. That's just for VRs. Ideally you need to set the timing and mixture again. You do need to wind the motor up to see the extra power. Gavin Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 19, 2005 yeah so ive been told. Ill have to get it sorted. cheers Gav Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 19, 2005 If the car was runnig correctly, you should see a massive difference just by adding these 2, if not then the engine needs setting up and timing checked, doesn't need to be on a rolling road but it needs to be someone with experience of G60 tuning and someone who has a wideband! Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 19, 2005 a wideband? was thinking JABBA ONLY because theyre closer then G-werks. Im up in Leeds, any suggestions? Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 19, 2005 Buy your own. Steveo29 bought one from ebay pretty cheap. PM him and say I said you should. Gavin Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted September 19, 2005 as a start set your ignition timing to 6 degrees BTDC and your co pot to 600 ohms, then get it tuned,, I have a wideband,, but i`m in devon Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 19, 2005 i paid about £175 for the widband kit......you could always sell it on once your done Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted September 19, 2005 175 thats cheap, must of payed about £250 for my innovate LM1 with the import tax,, well my mate did as payment for me doing a supercharger conversion on his integra,,, Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 19, 2005 arent sure what im doign so id rather someone else do it. someone who know what the ARE doing Quote Share this post Link to post Share on other sites
