bix
Power run :)
Nice... what mods have you done?
That dip at 5500rpm looks like it could do with sorting though... I think this is normally the sign that the hall sender's not 100% happy... :?
Spec: l&s cartec rsr charger(not great I think), 68mm pulley, red tops, schrick 268/276, sns s5 chip(could do with mapping i think), golf fmic, k&n panel filter, milltek.
Think the plugs and lead are past there best, but dunno if this would cause the dip? Would have put the 65mm pulley on if I was planning on getting a power run done, but I only went to get wheel alignment done, couldnt resist the dyno :) steering is soo much smoother now and it goes in a str8 line :-P
What am i missing? In the owners manual it says G's are 225lb/ft as standard!!
Looks good tho, nice power curve.
I think you'll find thats Nm (newton(100g) meters), which aint lb/ft
nice 8)
can you actually have the chips mapped then? tweaked? :?
Yeah, I dunno where tho?
nice 8)
mmmm,so the sns can be tweaked to suit the individual application then?
darren? do you have the facilitys to do this?
neil.
Cheers 8)
I think the dip around 5.5k is where the supercharger belt starts slipping :|
Slippage never a good thing.... how's your dizzy? I hear a worn one can cause a power dip at 5500rpm, Henny and GMan/Pitstop will know more on that....
Yeah having said that, you can hear the belt slip at about 4.7k, but looking on the mfa I think the boost did drop off a bit around 5-5.5k so thats prolly what it is.
Is there any way of tightening the belt? You mean the serpentine, or the internal one? Sorry, my G Lader knowledge is limited... but I have read on a few occasions about an unexplained power cut at 5500rpm being caused by a worn distributor. Not saying that's your problem for sure, but it's worth looking at :-)
Yeah I have a smaller belt, tensioner is ok too, even tried packing the spring down a bit, didnt seem to make a lot of difference :|
just looking at the plot again,does it produce power right upto 6300ish? rpm?
is that not really good going for a g?
mines flat as a fart after 5k :?
but the dizzy bussiness sounds a possability...
Nice figures mate. The torque figures from the Gs allways make me wonder whether i should have bought one instead of the vr, that eternal question!
When the noise tingle dies i'll prob think a bit more! Will henny get his RR'd, i'd love to see the figures on that puppy?
