khurrado 0 Posted October 13, 2005 where the f does this wire go? I assume its the neutral or live conn for radiator, but cant find a home for it...thus my fan only tunrs on when my car is turned off?????? right Quote Share this post Link to post Share on other sites
RW1 0 Posted October 13, 2005 The fan cut - off thermoswitch is on the forward driver's side corner of the rocker cover. (Where the red coloured digits are in the photo bottom left corner, slightly further towards the front of the car.) Have a look round there but I presume there's more length of wire around than is visible in the photo. . Quote Share this post Link to post Share on other sites
khurrado 0 Posted October 13, 2005 ok,, bottim right. And no there snot much more witre at all. I havent found anything for it to fit to, one guy on the forum a while back mentioned athat it fasted onto a nut????? Quote Share this post Link to post Share on other sites
RW1 0 Posted October 13, 2005 Can't make it out, whats the colour of the wire (* with * stripe)? It looks like a 16v, what year? . Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 13, 2005 Can't make it out The picture or the spelling? Quote Share this post Link to post Share on other sites
RW1 0 Posted October 13, 2005 Colour of the wire in the picture. . Quote Share this post Link to post Share on other sites
khurrado 0 Posted October 13, 2005 its brown and white if memories serves me correct just above the pic is i have beeen told an earth metal thingy near the top of the strut, ive stuck it on there radiator fan is cool now! but id stil liket o know exactly where it goes its def the neutral wire, live is already connected, as the fan will turn on at random times Quote Share this post Link to post Share on other sites
Baz2004 0 Posted October 14, 2005 There should be a temp sensor that it connects to on the rocker cover as RW1 said near the bottom left corner in the photo. Quote Share this post Link to post Share on other sites
khurrado 0 Posted October 14, 2005 ill have a look now cheers baz Quote Share this post Link to post Share on other sites
khurrado 0 Posted November 21, 2005 no luck cant find it! And ive really looked hard. Quote Share this post Link to post Share on other sites
RW1 0 Posted November 21, 2005 Is there at least a threaded hole where you've been looking, ie. someone has removed the sensor? . Quote Share this post Link to post Share on other sites
khurrado 0 Posted November 21, 2005 not sure, ill put soem pics up soon. Quote Share this post Link to post Share on other sites
RW1 0 Posted November 21, 2005 OK, I was going to suggest that. It's not a big sensor, about 1 cm diameter. . Quote Share this post Link to post Share on other sites
khurrado 0 Posted November 21, 2005 rw1, if u can can u copy the pic above, and highlight where i should be looking? thanks Quote Share this post Link to post Share on other sites
RW1 0 Posted November 22, 2005 Bottom right of pic near oil filler on rocker cover. Forward and to right hand car side of filler hole. . Quote Share this post Link to post Share on other sites
khurrado 0 Posted November 22, 2005 sorry, reiterate pls, from the oil filler. Forward and to the right, sounds like spark plug from that pic above. Quote Share this post Link to post Share on other sites
Toad 0 Posted November 17, 2006 the sensor is bolted down with one of the rocker cover bolts Quote Share this post Link to post Share on other sites
