dutch 0 Posted October 17, 2005 Ok, just got back from Toronto the other day and I was hoping the Corrado would have healed but no luck...... :oops: I did a full service on the C before I left..plugs,leads,cap and rotor etc and she run good for a few days before it devolped this spudder. Between 1.5 and 3000 rpm it tends to hesitate...i'm thinking fueling problem but not sure... the other thing is the C seems to have an annoying pull to the left and it's getting worse!! any ideas? thanks d Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 17, 2005 What model is it? Tried VAGCOM? Quote Share this post Link to post Share on other sites
dutch 0 Posted October 17, 2005 VR....before I left a mechanic plugged in it but nothing was coming up...of course it was runiing fine then....will try it again... Quote Share this post Link to post Share on other sites
VR6 0 Posted October 17, 2005 Moving to Engine Bay. Quote Share this post Link to post Share on other sites
Tempest 0 Posted October 17, 2005 Timing out? Tempest Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 17, 2005 I have the same problem Gonna try changing fuel filter see if thatr works Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 17, 2005 Since you've ruled out spark (well .. you've replaced all the relevant bits) it must be fuelling, but that sort of symptom is less likely to be lack of fuel, and more likely engine sensor issues causing the ECU to misfuel. Perhaps there's an air leak on the inlet piping, post-MAF? Could be the MAF itself, too. Quote Share this post Link to post Share on other sites
