Nick
SQUEEL like a little girl!
My C seems to have developed a problem. On most occasions, when at full lock, my car starts to make a horrible squeeling sound. I thought it was just rubbing, but it happens even when im at full lock stationary, in both directions. Any ideas?
Power steering belt slipping, maybe it just needs tightening, easy job on a g60, from underneath, just have too loosen a 13mm bolt and tighten the tensioner 13mm bolt!
yup, with Bix here... you may also want to replace the belt depending on condition... it's only a few quid, so it's well worth doing if the belt is shiney or cracked in appearance... 8)
I know for a fact that my car needs its tracking sorted, but thats because i played with the suspension, it was doing this noise a long while ago, so ill check the belts and my fluids (if you pardon the expression)
