kasman21 0 Posted October 18, 2005 hi guys I running a few ideas in my head!! 1.8 16v engine ported and polished head by tsr ported and polished 52mm inlet 4 branch stainless exhaust manifold full stainless exhaust power rohr k&n panel filter, drilled box Its running nicelyy at present but anyone got any ideas how to increase it further or maximise what ive got?? ie 42 inlet??? exhaust cams???-whats the procedure for that is it easy?? anything else??? cheers all any advice or tips would be great! zak Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 18, 2005 hi guys I running a few ideas in my head!! 1.8 16v engine ported and polished head by tsr ported and polished 52mm inlet 4 branch stainless exhaust manifold full stainless exhaust power rohr k&n panel filter, drilled box Its running nicelyy at present but anyone got any ideas how to increase it further or maximise what ive got?? ie 42 inlet??? exhaust cams???-whats the procedure for that is it easy?? anything else??? cheers all any advice or tips would be great! zak 2L 9a, 6a or tall block ABF or ACE bottom end (2L 16v blocks from Passats, corrados, audis and seats) , for between 100 and 500 quid for the block you'll increase power and torque. Anything up to 200bhp is possible on the K-jet system from the KR(1.8 engine code), 160-180 on KR cams. my engine output David. Quote Share this post Link to post Share on other sites
conleycrew3 0 Posted October 18, 2005 try this, sounds fun too http://the-corrado.net/.archive/forum/viewtopic.php?t=31404 Quote Share this post Link to post Share on other sites
conleycrew3 0 Posted October 18, 2005 even better try this..... http://cgi.ebay.co.uk/VR6-2-9-Litre-Eng ... dZViewItem Quote Share this post Link to post Share on other sites
kasman21 0 Posted October 18, 2005 whats the mod with exhaust cams??? what engine code m i looking for in the 2l bottom end???should i get any work done on the bottom end?? is 42mm better or 52mm inlet??? thanks guys zak Quote Share this post Link to post Share on other sites
Bobby 0 Posted October 19, 2005 like david said a 2l bottom end kr head port and polished ,42mm manifold and two exhaust cams, thats what you want then book a tune up with stealth. Quote Share this post Link to post Share on other sites
