DragonAttack 0 Posted October 24, 2005 Just topped up the oil in my VR and noticed a small smearing of white residue on the underside of the filler cap. There's been no obvious symptoms of anything untoward though the motor has been idle for long periods recently and a (fairly) recent coolant leak was sorted by changing the pump and some other bit that had broken. There appears to be a very light coolant loss over the last 2-3 months also but this is barely noticeable. Am I in a bit of bother? Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 24, 2005 Is it still there after you take the car for a good run and get it fully warmed up? If it's not, then don't worry about it. Quote Share this post Link to post Share on other sites
mr.ots 10 Posted October 24, 2005 If you are losing coolant and have a white residue in the filler cap it could be a leaking head gasket and water contaminating the oil. Check the water in the expansion tank to see if there is anything untoward in there? Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 24, 2005 Or it could just be condensation? Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 24, 2005 Commonly termed as "mayonnaise". Usually caused by short journeys where the engine doesn't fully warm-up & condensation does not have time to evaporate. The fact that your car has been idle for a while could also cause this. Head gasket would usually have gone completely by now, if it's been leaking for 2-3 months. Small coolant leaks can usually be found by looking for residue - around the pipe connections, etc. Quote Share this post Link to post Share on other sites
DragonAttack 0 Posted October 25, 2005 Cheers guys, going to Aberdeen tonight so I should find out a few things good or bad!! Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 25, 2005 i've had a small amount of mayo in my VR oil cap for the past 4 years of ownership,its nothing more sinister than condensation,it'll dissappear by the time you've done over 5miles on a trip and the engine has properly warmed up Quote Share this post Link to post Share on other sites
DragonAttack 0 Posted October 26, 2005 No probs. All seems to be well. No more "mayo" and we cuffed United. Just need to get the MOT out the way now. Quote Share this post Link to post Share on other sites
