Dougalo
What is this called?
Hi Guys,
What is the bit called where the water hose goes into the engine on my valver (on the right hand side, next to the temperature sender) called? The hose is in good condition and i'm losing a lot of water from this area. Is it some sort of gasket?
Also, would i be best getting this part from the dealership?
Cheers in advance!
I think on ETKA it's called 'outlet' or something equally vague (as per usual) like 'part'.
I usually hear them referred to as elbows.
Flange, what a word I can't use that word in serious conversation around my g/f as she just wets herself
Sounds like you need to replace the O ring...
Thought this sounded familar so checked an old invoice and this part is indeed known as a "coolant flange" :lol: :oops:
I could say something here about females, servicing and coolant flanged but I'll just leave it...
:lol:
Yes, should be fairly easy on a 16V, as there isn't that much tubing in the way unlike with a G60 :lol:
Changed the coolant flange on my DX and PG-engines, definitely preferred doing the DX :lol:
Good time to then also flush the entire cooling circuit and refill with fresh G12+ mixture :-)
Tempest
Had a look at GSF online, but i have a few flange options. Can someone please tell me what I need from the list below?
PN Description Fitment Price() Basket
11734B CRANKS.SEAL.FLANGE GASKET General Use. Most Water Cooled (Opposite End to Flywheel Seal) 1.00 Add
17953 WATER FLANGE ON HEAD-SIDE CO G60 9/88 > 5.90 Add
17953G WATER FLANGE ON HEAD-SIDE CO 16V 4/89 > 5.75 Add
17953R WATER FLANGE CO 4 Cyl 9/88 > 4.00 Add
17980 HOSE-W/PUMP TO FLANGE CO 16V 4/89 >3/91 23.60 Add
17983B HOSE-PUMP TO FLANGE DIES CO 16V 4/89 > 5.00 Add
11734C CRANKS.SEAL.FLANGE GASKET CO 9/88 > 1.00 Add
Cheers
id assume its the
but you might want to give them a ring, give them the part number and let them tell you which one is right!
My guess would be that one.
Go into GSF and they'll show you it on their screen.
I don't live near a GSF so i'll prob just go to my local VW garage and get someone from the parts dept to tell me.
Cheers
Flange, what a word :lol: I can't use that word in serious conversation around my g/f as she just wets herself :-)
That made me chuckle!!!
Wonder what she's think ing about the little tinker! :lol: :lol:
Chris
