Tempest 0 Posted November 8, 2005 OK, after another good use of my fuel pressure gauge gadget on my G60 fuel rail, I can now safely conclude that the most likely reason for my starting/stuttering problems are an ageing fuel pump. As I have already had an attempt at getting the thing out of my tank (single in-tank fuel pump) I couldn't get that blasted white locknut off. Tried hammering it off with a chisel/screwdriver, but to no avail, haven't got a water pump with big enough jaws :x What tool do I need? Tempted to just break it off, as it's only a few quid from the stealers :roll: Tempest Quote Share this post Link to post Share on other sites
Jim 2 Posted November 8, 2005 I watched Vince do this on kevhaywire's fuel tank a few weeks back and thats basically all he did. Yours must be on super tight as a few stern whacks with big chisel and a rubber mallet and it started to go.. Quote Share this post Link to post Share on other sites
RW1 0 Posted November 8, 2005 Try putting a hot towel in a stout plastic bag round it (heavy duty shopping bag?) and see if it will expand relative to the tank threads. Leave it there for about 5mins for the heat to absorb into the plastic. Then see if it will give. . Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted November 8, 2005 try using an oil filter remover,the bar and chain type,worked great for me Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted November 8, 2005 or a boa grip they are awesome and will not damage anything Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 8, 2005 Or use an old golf type fan belt if you have one lying around? Quote Share this post Link to post Share on other sites
Tempest 0 Posted November 8, 2005 try using an oil filter remover,the bar and chain type,worked great for me Was thinking that myself, will have to check again, whether I have enough clearance around the nut to insert the chain and socket. Yours must be on super tight You bet, it's usually the seemingly simple things that go horribly awry on my cars :lol: Tempest Quote Share this post Link to post Share on other sites
Lippy 0 Posted November 8, 2005 u need some Spinach Eric! ag gag gag gag Quote Share this post Link to post Share on other sites
Tempest 0 Posted November 8, 2005 u need some Spinach Eric! Believe you me, already tried that :lol:, otherwise I wouldn't be asking here for help ;-) Will try some of the suggestions as soon as I find some time (back home again, weather fine, not dark out there, etc. :lol:) Tempest Quote Share this post Link to post Share on other sites
