billinjah 0 Posted November 26, 2005 having complete brain freeze! laying under the valver spanner in hand! do i need to take the p/s pump off? didnt have to in the g60 thought they might be the same? edit: did the thermostat and no difference still running at 100 and not really coming down. feels like system is being pressurised and when i run it with the exp cap off it shoots the water out in spurts could it be the headgaskets gone? no oil in the water as far as can see and no water in the oil. Quote Share this post Link to post Share on other sites
JBOB 0 Posted November 26, 2005 The PS pump needs to come off and theres a hidden bolt behind it so look out for it :lol: Then unbolt the water pump and replace the thermostat. (Thats what I think I did anyway :lol: :lol: ) Quote Share this post Link to post Share on other sites
Valerian 0 Posted November 26, 2005 Thermostat housing is underneath the water pump. Follow the bottom hose from the radiator and you'll find it. Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 26, 2005 you have to remove the water pump? Quote Share this post Link to post Share on other sites
flusted 0 Posted November 26, 2005 you have to remove the water pump? No,2 10mm bolts on water pump flange that goes to bottom of rad,undo em and thermostat is in there Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 26, 2005 No,2 10mm bolts on water pump flange that goes to bottom of rad,undo em and thermostat is in there cool so same as g60 really i was just being simple! Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 27, 2005 mmmm just had a chat with a mate he suggested maybe its fine and the temp sender is giving bad readings as the car is running fine and doesnt seem to be loosing anymore water, ive also noticed there is a sender on the side of the head thats spade connector has snapped off so its not doing anything?! Quote Share this post Link to post Share on other sites
