Valerian 0 Posted November 28, 2005 Just noticed my reverse lights are not working. Been staring at the top of the gearbox as i presume there is supposed to be a reverse light switch there somewhere. Doesn't seem to be any wires connected to any part of the gearbox unless it's underneath. Quote Share this post Link to post Share on other sites
vwcorrado 0 Posted November 28, 2005 it is mate , near gear oil drain plug. Quote Share this post Link to post Share on other sites
Valerian 0 Posted November 28, 2005 okey doke......didn't look underneath coz it's been raining here will look tomoz....many thanks Quote Share this post Link to post Share on other sites
White2505 0 Posted November 28, 2005 on top of the gearbox selector mechanism is a black housing with a connector on it. This is held on by two bolts. Undo and remove and you should see a switch inside the housing. My problem was the mild steel cup bolted on top of the selector mechanism which then actuates the switch within the housing. On mine the bolt had undone so the cup did not apply enough pressure to activate the switch Quote Share this post Link to post Share on other sites
Valerian 0 Posted November 28, 2005 on top of the gearbox selector mechanism is a black housing with a connector on it. This is held on by two bolts. Undo and remove and you should see a switch inside the housing. My problem was the mild steel cup bolted on top of the selector mechanism which then actuates the switch within the housing. On mine the bolt had undone so the cup did not apply enough pressure to activate the switch Is this on the top of the gearbox or underneath? Quote Share this post Link to post Share on other sites
White2505 0 Posted November 28, 2005 on top of the bellhousing to the right and further towards the nose of the car than the flywheel inspection holes. Not very clear but the black plastic housing pictured is what you're looking for Quote Share this post Link to post Share on other sites
vwcorrado 0 Posted November 28, 2005 i must be lookin at wrong gear box in book sorry mate. Quote Share this post Link to post Share on other sites
Valerian 0 Posted November 28, 2005 on top of the bellhousing to the right and further towards the nose of the car than the flywheel inspection holes. Not very clear but the black plastic housing pictured is what you're looking for I did look at that but couldn't see any wires coming from it. will check again tomoz. Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 3, 2005 Just been out to look at the C during a break in the rain. Found the reverse light switch although it looks like nothing i have ever seen before...lol Connected the wires together that go to the switch and the lights work so it looks like the prob is the switch. Unbolted the switch and there seems to be a lot of grease in there. I notice that the cylinder part of the switch mechanism that is bolted to the linkage is held by one nut.....is this cylinder adjustable or is it fixed in one position i.e. slotted to the linkage? Also does anyone have any idea how much a new switch costs from VAG. Quote Share this post Link to post Share on other sites
Henny 0 Posted December 5, 2005 new switch is about £25 from VAG... broke mine installing the gearbox into H-YYU :oops: Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 5, 2005 new switch is about £25 from VAG... broke mine installing the gearbox into H-YYU :oops: Just phoned my local VAG dealer and the reverse light switch was quoted as around £8+VAT. Also quoted me £17+VAT for an ignition switch. Quote Share this post Link to post Share on other sites
Henny 0 Posted December 5, 2005 ah, that's JUST the switch part... you may also need the big bit which it clips into which is the bit I also broke and makes it up to around £25... ;) :oops: Quote Share this post Link to post Share on other sites
ManBoo 0 Posted December 5, 2005 reverse light switch (9) £8.23+ and sleeve (12) £2.73+ from us Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 5, 2005 is it possible for the sleeve to be out of adjustment or rather bolted down incorrectly therefore not activating the switch when it should be? Quote Share this post Link to post Share on other sites
ManBoo 0 Posted December 5, 2005 I'd assume the sleeve only goes on one way mate?? Although i'm not a mechanic.. i only supply the bits.. i can find out tomorrow for you though... unless someone else knows?? Quote Share this post Link to post Share on other sites
Valerian 0 Posted December 5, 2005 Hmm ...if it's keyed to the linkage then i guess it can't move .....was going to unbolt it and have a look but the weather put a stop to that. I've ordered a switch from the VAG stealers now anyways. Quote Share this post Link to post Share on other sites
cata 0 Posted October 28, 2006 Anyone have a part # handy? Would like to know the price around here before fidling with it. Quote Share this post Link to post Share on other sites
cata 0 Posted October 29, 2006 Anyone? A part # would really help. Quote Share this post Link to post Share on other sites
fla 9 Posted July 12, 2010 i've just recently adjusted my gear selector (gearbox end) and now the reverse lights dont come on. This is because the circuit is not being completed in the switch on the box. Is there any way to adjust this at all, or perhaps a better way to set up the gear selection without putting everything out of position? Quote Share this post Link to post Share on other sites
fla 9 Posted July 14, 2010 i'd just like someone to check at which position of the gearstick the reverse lights actually come on - is it when you press teh gearstick down or when its at the fullest extent of travel? Quote Share this post Link to post Share on other sites
