kongo127
Corrado
I have a friend who has a 1991 Corrado.
Mine is a 1990.
He doesn´t have a ECU in his car which has been rebuilt.
He would like to run it for a while.
Can i put my ECU in his car?
I believe i can because the pinout is identical.
The only difference is that his car has A/C and mine has not.
What do you think?
No worrys mate,when i was building my G60 charged 2.0 valver engine i put the wrong injectors in by mistake thus blowing the ecu's drivers,i then fitted a spare unit with a different number and the engine ran i then tried yet another 1 with a stg 4 chip and a purple sticker,no problem.
For the G60 there were in principle 2 ECUs: One with a B-ending, and one with a DP-ending. The latter was said to be a wee bit quicker, due to the slightly faster components used inside, but this was negligible in terms of bhp-increases. It eventually all boils down to the chip you're running.
A/C-pin: If this isn't wired through, then the idle speed won't be adjusted whenever the A/C is switched on, as the A/C pin passes to the ECU a signal from the A/C switch in the mid console control. This again will only work, if the chip has a suitable setting, i.e. is A/C aware.
So in terms of answering your question: Yes, you can run almost any ECU, as long as the chip is suitable for the set-up. I even ran a CR-ending ECU, but with Zoran's chip, no problem.
Tempest
Yes, you guys are correct.
I have changed the ECU´s this morning without any issue.
Everyting ok.
Thanks for the advices!
