steveo29
questions about oil coolers for g60
okay ive seen all the threads about oil coolers and how i should i have one
a few questions..
i do alot of shorter journeys where the car only just gets to temp, i dont wwant a set up that stops the oil getting up to a useable temp quickly..what ones have a proper stat that will allow it to heat well
and where do you fit them...i have a fmic
Oil coolers haave stat built into the sandwich plate(sandwich plate takes place of existing water cooler)
Being honest, mine doesn't heat up that quickly.. I only got mine because once warm you get scary temperatures 100+
You can mount the cooler pretty much anywhere if the pipes are long enough. Where exisiting intercooler was for example
Temps above 100 aren't a cause for concern. Temps above 120 are though! Mine goes up to about 108 on the motorway at 80mph which isn't too much to worry about and I run a small cooler.
Neil G60, Thats pretty hot mate.. Mine is runing a 13 row mocal iirc and temps at 80 are around 80deg C
Tempartures are very dependant on how you drive though :D
I still see 110 line.. but have to be very naughty.
I'm quiet happy driving along with oil temps at 80deg.. but it comes down to what you feel comfortable with and what you think will preserve your engine the longest.
doesnt a themostat work these coolers - so G60Dub, what temp does your kick in? I think I can remember 90degrees being the standard for the 13rack ones like in your picture??
_leon_, No, Its what Darren @ G-Werks suppied with the kit.
The kit really is for the summer. It'll run at 90 at 80mph in the sun. Winter does cool it alot more.
_leon_, First time round no. I had to change bits over though to the new Corrado. I fitted it then. Quiet easy to do, however I did use Darrens 90deg air drill to get the holes in the right place.
FurkiG60, In this weather probably 82-85? I guess. Summer little over 90?
I run a Mocal oil cooler great job if your doing 70mph all the time :-P
Engine Bay finished :D Below
Oil Cooler fitted engine bay not finished :(
the stats that we supply in our kits are 80*deg if you go bigger than a 15row 115 cooler you will have some issues in getting the oil warm enough in the sort of weather we are experiancing at the moment espically on cars with the bigger rads
