-Neil- 0 Posted January 3, 2006 from the elbow in the air inlet pipe underneith there are two pipes, one goes to the brake servo vacume thing, where does the red lined pipe go to on the engine? Please help me! Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 3, 2006 its a 2ltr 16v 1993 aswell, anyone any ideas? Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted January 3, 2006 does it goe to the airflow meter/ airbox i took mine apart last week sure it does Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 3, 2006 where abouts is that as you look in the engine bay? Quote Share this post Link to post Share on other sites
corradophil 3 Posted January 3, 2006 where abouts is that as you look in the engine bay? The side of the airbox. There is a round diaphragm which it operates. Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted January 3, 2006 yeh thats it Quote Share this post Link to post Share on other sites
flusted 0 Posted January 3, 2006 it links into the run on valve and airbox Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 3, 2006 ok i have plugged it into there, would it make any differnce to the idleing or running of the car baring in mind i've been driving it since i've brought it without this pipe connected for about 4 months now, would it cure my troubles in the car taking a while to start up in the morning? Quote Share this post Link to post Share on other sites
corradophil 3 Posted January 3, 2006 The long hose connected to the airbox operates a flap to switch between cold and hot air intake. The cold air is drawn from behind the O/S headlight, the hot air from the exhaust manifold via a large ducting pipe if it's still there. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 3, 2006 damn, just remembered i didnt put that ductiing pipe back on, WHOOPS! gotta do that in the dark now! this is where i plugged that pipe to.... Quote Share this post Link to post Share on other sites
Valerian 0 Posted January 3, 2006 yup .....thats the correct place Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 3, 2006 thanks guys, couldnt of done it without you! Love you all! Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted January 3, 2006 gee thanks. just goin off topic my warm air hose has been replaced with that silver bendy crap and is worse for wear would this effect running? where can i get a new 1 tried stealers £35 Quote Share this post Link to post Share on other sites
Valerian 0 Posted January 3, 2006 It would probably be cheaper to get another cheap bendy silver pipe. Available at most good motor factors or failing that ...Halfrauds Quote Share this post Link to post Share on other sites
flusted 0 Posted January 4, 2006 Just bin it! its only there to help car running in -10 degrees which you wont get in uk anyway (i dont think) Quote Share this post Link to post Share on other sites
