olly elworthy
g 60 KNOCK SENSOR
that sounds a bit better cheapest i have found so far is £68 + vat,,
just want to change it as car has done 80K and cant seem to get much timing on it when tuning,,
mine looks mint but i still wanna change it,, so i will defo be buying a new one
have you tried testing it using the timing light method ? there might be need need to spend £48.00
is that where you set the car running with the timing light on then give it a tap to see if it retards under knock? not tried this yet,, must give it a try,, car seems allot better with a fresh tank of fuel,, bought some optimax the other day and im not quite sure for that tank at least,,,, it was exactly what it says on the tin!! :?
brother and i filled up at the same garage at the same week and cars were not right for teh whole duration of that tank of fuel,, seems back on track now though,,
