scruffydubbers
building a 16v g60
HI,
i have got a corrado 16v and was thinking about building myself a 16v g60,
this is the plan that i ve got so far, but if anybody had any advise or think of anythink i have forgotten then please let me know
i was going to try and get hold of a complete g60 engine,
buy the pulleys brackets for the 16v from bahnbrenner.
use a g60 intercooler,
run the engine on the g60 ecu and wiring.
lower the compression of the engine initally using a thick copper head gasket from bahnbrenner,
homefully then run the engine on a large pulley running low boost and if it all works well,
start building myself a low compression bottom end so i can eventually run higher boost levels.
i was unsure about what inlet manifold to use i know that a scirroco one can be used but i would like to use a 20vt style one, i heard that a audi s2 one can be modified to fit?
any help on this would be greatfull
thanks
