-Neil- 0 Posted January 25, 2006 For the first time of me owning a corrado im doing my first DIY job! Im replacing my passenger bottom ball joint tomorrow. i have the new ball joint. I take it its just a case of unding the top bolt, hitingt the arm down, then undo the bottom 3 bolts? If there are any pointers or any help anyone has got please give them to me! Neil Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 25, 2006 That's more or less it, but you may find a ball-joint splitter is easier than smacking seven bells out of the wishbone. The forked type aren't very expensive and work very well. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 25, 2006 first of all, you'll need a ball joint splitter, or you'll never get it out. slacken wheel bolts jack car up remove wheel undo 17mm nut and bolt in bottom of hub carrier. hammer the bolt out (it'll be tight) use ball joint splitter and hammer to get ball joint out of hub carrier undo the 3 13mm bolts holding the ball joint to the wishbone clean up all the bolts with a wire brush and apply copper grease to the threads fit new ball joint to wishbone use a screwdriver to line up the bolt holes refit 13mm bolts but don't tighten just yet apply a bit of grease to new ball joint push down wishbone and swong hub assenbly over then let go of wishbone to allow the ball joint to go up into the hole give wishbone a tap from underneath with a hammer to make sure the groove in the ball joint is lined up with the hole fort he bolt you took out first refit 17mm head bolt and renew locking nut reift wheel drop car back down check camber jack back up and adjust ball joiint as necessary tighten all bolts go and get tracking.geometry set properyl befor eyou wear your tyres out sorted. I will stress again, you will NOT get it out without a ball joint splitter. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 25, 2006 Probably not the place for this, but NICE PIC PHATVR6! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 25, 2006 LOL - I may be wrong but, if it's an original BJ don't you need new bolts and the plate that they thread into... Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 25, 2006 never said you did. but if it's never been off, it's odds on they'll either snap or round off. single hex sockets are what you need. class avatar eh! Quote Share this post Link to post Share on other sites
billinjah 0 Posted January 25, 2006 so the bolt that hold the bj on isnt threaded? mines well tight i smacked the cr*p outa it and no budgie shal i warm it up and schmack it some more ya? Quote Share this post Link to post Share on other sites
s.g 0 Posted January 25, 2006 i would advise a ball joint splitter, as it took me hours to get my out without one and i got a new plate + bolts with mine. Quote Share this post Link to post Share on other sites
s.g 0 Posted January 25, 2006 so the bolt that hold the bj on isnt threaded? mines well tight i smacked the cr*p outa it and no budgie shal i warm it up and schmack it some more ya? which bolt are you on about? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 25, 2006 the hole in the hub carrier isn't threaded, no, the bolt will just be rusted into it. wind the locking nut off,but also still try and turn the bolt itself to break off the rust. just be careful with heat, you'll melt the DV boot if you're not. also, this does not apply to VR6's, as they don't have the through bolt, they have a big nut on the ball joint, and a STUPID socket i the end of the ball joint, whixh is just so feeble and weak that it just splits every time and is utterley uselss for holding the joint still. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 26, 2006 i do have a ball joint splitter in the garage luckiy, When you say adjust it if i need to, are the 3 bolts oblonggated? Quote Share this post Link to post Share on other sites
s.g 0 Posted January 26, 2006 i do have a ball joint splitter in the garage luckiy, When you say adjust it if i need to, are the 3 bolts oblonggated? yes, you can always mark where the plate is before taking it off then when you put it back on you can get it somewhere near but i would definatly get the car re-aligned(spelling?) and tracked as soon as possible afterwards Quote Share this post Link to post Share on other sites
Madjackal 0 Posted January 26, 2006 When i did mine i bought new bolts and locking plate from VW. for 7 quid it'd be rude not too. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted January 26, 2006 It's easier to push the bottom wishbone down if you undo the anti-roll bar drop link. It's best to get the camber checked afterwards even if you have marked the position of the plate. Best wishes RB Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 26, 2006 well i did it, only took 4 hours! 3 and half of them was trying to get the sodding ball joint out of the hub! Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 26, 2006 lol! even with the splitter? Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 27, 2006 lol! even with the splitter? errrrrr.....well my mate had it and he was at work and i had the car in pieces so i couldnt get, that'll be why it took so long! Quote Share this post Link to post Share on other sites
