zacon 0 Posted February 9, 2006 I am thinking about GSF part no. 18389. The 2.0 is a '92 model. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted February 9, 2006 If the 2.0 16v has the same two-pump setup as the 1.8 16v, then I'd expect so. I'm pretty sure some Corrado's have a single pump system though. Quote Share this post Link to post Share on other sites
zacon 0 Posted February 9, 2006 I am pretty sure the 2.0 has the same two-pump system. I know (most) G60's have a single pump which is located in the tank. Quote Share this post Link to post Share on other sites
khurrado 0 Posted February 9, 2006 i changed my fuel pump last year for my 2.0 16valve, it cost me 15 quid from volkswagen spares in hammersmith. Im not too technically minded as far as cars are concerned, but its seemed to be a single unit, connected to the fuel tank. Correct me if im wrong. Quote Share this post Link to post Share on other sites
zacon 0 Posted February 9, 2006 I believe there is another one inside the fuel pump, which I think is broken in this case. The car runs fine on full tank. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted February 10, 2006 Well, if your car has a main pump under the floor near the rear driver's side wheel (and I'm betting it has) then it's definitely got a pump in the tank. Since the 2.0 16v fuel system requires the same pressure as the 1.8 16v I'd bet that the pumps are the same. Unfortunately I can't tell you for definite as my copy of ETOS has expired :( Quote Share this post Link to post Share on other sites
