PoorMansPorsche 0 Posted February 12, 2006 alright peeps, First off i do know and have used the SEARCH !! Basically i want my valver handling and steering like when it came out the box so if someone could do me a list starting with all the wearable parts which generally need to be replaced so i can get it ticked off. As i doubt anythings been changed and as its 16 years old im pretty sure everything needs to replaced. I do not want to fit any aftermarket lowering kits or anything like that (as my brain is spinning after reading all the other posts!!), i just want it to be like it should. Also if there are any parts that are better / cheaper than VW ones let me know ! Say for example that £130 bush kit from Venom? I know all things have been covered before but a nice easy to understand list would be great cheers Brett Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted February 12, 2006 Just about to do this on mine hopefully - so far it'll be new wishbones and all the bushes at the front (OE), and new OE bushes at the back, but I'd be interested to know what other things people recommend... :) Quote Share this post Link to post Share on other sites
lukeage 0 Posted February 12, 2006 This would be a good one for the knowledge base. First thing a lot of people want to do when they join the forum is lower there newly acquired 4x4 and / or swap out all of the other related components still on from when it was new. A couple of others to add to the list: Bumpstops, Top mounts. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted February 12, 2006 It just so happens I'm rebuilding a mk2 golf at the moment in preparation of an s3 engine install. I'll post up some pics (with the car owners permission) as I'm refurbishing all the parts so you can see what's involded. The phrase "better than new" springs to mind, Quote Share this post Link to post Share on other sites
lukeage 0 Posted February 12, 2006 PhatVR6, nice one! Quote Share this post Link to post Share on other sites
red corrado16v 0 Posted February 15, 2006 Just doing mine today,word of warning BRETTLOVEDAY,get your self some new brake hoses flexi and fixed as mine where seized solid and had to be cut off before i could remove rear axle to fit new bushes(polysport)http://www.rallydesign.co.uk/catalog/product_info.php?cPath=533_741_761&products_id=5127 this will also make the job far easyer when you come to refit the axle as everything is all new. If youve got access to a brake line flaring kit make yourself some new brake lines for the rear axle while it is off,I bought some brake line (40p per foot)and new fittings (12p each)from a local motor factors.Good luck,very satisfying to know you have done it all yourself and saved a bundle in the process. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted February 15, 2006 Right i have done exactly this when I did my transplant and rebuilt my car. I will try and remember everything but I am sure I will forget some of the stuff I did. This purely for the suspension and I will not include brake stuff or engine mounts although i did all that too. Front End: Your choice of shocks and springs or coilovers.... Powerflex Front Crossmember bushes Powerflex wishbone bushes front and rear OE bottom balljoints OE Track rods OE Track rod ends New Steering rack (big debate at the mo with this) Powerflex steering rack bush VR6 top mounts and bearings OE wheel bearings Check the column and UJ's for slack... Rear Your choice of shocks and springs or coilovers... OE rear beam bushes OE rear top mounts OE rear wheel bearings Thats your basic rebuild on the suspension. Jay Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 15, 2006 Same here, although I'm taking the Powerflex cross member bushes out and putting standards back in because those + VT competition and VT road engine mounts is slightly too much. Causes a slight jolt through the car when the engine starts up from cold and clutch take up is a little aggressive. Quote Share this post Link to post Share on other sites
Andy T 0 Posted February 16, 2006 Forget the venom kits. As Jay says, use OE parts for most/all things, polybushes are good for wishbone/crossmemember & steering rack mounts, please don't use poly bushes on the rear axle, it spoils the handling! Quote Share this post Link to post Share on other sites
Ronan 0 Posted February 16, 2006 hahaha, going to re-visit this argument npw - heard it doesn't spoil the handling on a lowered car? ;) Quote Share this post Link to post Share on other sites
PoorMansPorsche 0 Posted February 16, 2006 well im not going to be lowering my car as it wont fit in my garage (extremely sloped drive and flat garage) apart from the 15mm lowering top mounts so it looks like OE's for me Quote Share this post Link to post Share on other sites
Andy T 0 Posted February 17, 2006 hahaha, going to re-visit this argument npw - heard it doesn't spoil the handling on a lowered car? ;) :) once had a go in C 16v that has rear polybushes, it just felt weird to me (I've always had vw's with the passive rear steer) the car felt less nimble, and twitchy, just my opinion though! Quote Share this post Link to post Share on other sites
