Blown 0 Posted February 12, 2006 So now that I've decided to get my arse in gear and do something with my G60(cos it's been stood in the parents garage,neglected, with the bonnet up for around 5 months now) the likliehood of having to remove the head is cropping up. If I do,I'd want to replace the headbolts with ARP ones but I've heard about different opinions on them. Any good,or not? Quote Share this post Link to post Share on other sites
H8RRA 0 Posted February 12, 2006 from what i know, you can't get better and i've had 3 supercharged corado vr's with nitrous bolted together with them :) 8) ....need any more convincing? ;) Quote Share this post Link to post Share on other sites
keithmac 0 Posted February 14, 2006 Mine runs arp headstuds, no complaints here (plus you can re-use them!). Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 14, 2006 Fitted my ARP bolts no problems to my 16v G60 build but can't comment on anything else as the engine is still in bits! Quote Share this post Link to post Share on other sites
flusted 0 Posted February 15, 2006 Apperantly they dont stretch like vws 1s so arent a good idea? Only what ive read Quote Share this post Link to post Share on other sites
H8RRA 0 Posted February 15, 2006 Apperantly they dont stretch like vws 1s so arent a good idea? Only what ive read ????thats the whole point. You can reuse them and change the torque setting dependant on your set-up. Never been a fan of stretch bolts and this ".......torque to x lb fts and then 90deg and another 90DEG......." Can never find a bloody protractor when I'm doing a head :roll: :? I've had mine on std setups, charged setups and currently charged with a spacer gasket without any probs feel a lot more comfortable with them than stretch bolts Quote Share this post Link to post Share on other sites
s.g 0 Posted February 15, 2006 Apperantly they dont stretch like vws 1s so arent a good idea? Only what ive read ????thats the whole point. You can reuse them and change the torque setting dependant on your set-up. Never been a fan of stretch bolts and this ".......torque to x lb fts and then 90deg and another 90DEG......." Can never find a bloody protractor when I'm doing a head :roll: :? I've had mine on std setups, charged setups and currently charged with a spacer gasket without any probs feel a lot more comfortable with them than stretch bolts just a quick question, would there not be a risk of treading the block if you happen to put to much torque through the bolt Quote Share this post Link to post Share on other sites
H8RRA 0 Posted February 15, 2006 Apperantly they dont stretch like vws 1s so arent a good idea? Only what ive read ????thats the whole point. You can reuse them and change the torque setting dependant on your set-up. Never been a fan of stretch bolts and this ".......torque to x lb fts and then 90deg and another 90DEG......." Can never find a bloody protractor when I'm doing a head :roll: :? I've had mine on std setups, charged setups and currently charged with a spacer gasket without any probs feel a lot more comfortable with them than stretch bolts just a quick question, would there not be a risk of treading the block if you happen to put to much torque through the bolt yes. isn't there a chance of killing yourself if you crash into a brick wall at 100mph? the answer is both is yes but why would you want to do either? Quote Share this post Link to post Share on other sites
Sprint 0 Posted February 15, 2006 If the engine is fairly standard just stick to standard bolts, they work fine. U should only need ARP head bolts/studs in extremes. Metal head gaskets require stretch bolts as they need a slight amount of 'give' so to speak. Even if you upgrade to a Cometic gasket only stock bolts should be used. Save your money for other things :) Quote Share this post Link to post Share on other sites
s.g 0 Posted February 15, 2006 Apperantly they dont stretch like vws 1s so arent a good idea? Only what ive read ????thats the whole point. You can reuse them and change the torque setting dependant on your set-up. Never been a fan of stretch bolts and this ".......torque to x lb fts and then 90deg and another 90DEG......." Can never find a bloody protractor when I'm doing a head :roll: :? I've had mine on std setups, charged setups and currently charged with a spacer gasket without any probs feel a lot more comfortable with them than stretch bolts just a quick question, would there not be a risk of treading the block if you happen to put to much torque through the bolt yes. isn't there a chance of killing yourself if you crash into a brick wall at 100mph? the answer is both is yes but why would you want to do either? i was only asking :lol: :lol: Quote Share this post Link to post Share on other sites
H8RRA 0 Posted February 15, 2006 sorry - forgot the smilies 8) ;) Anyways - if you're just doing a head - probably just as well with std - i'm always pulling engines apart so got arp's - a nice "to have" or necessity if fcukin around with the vr6 - don't really see why you wouldn't use them if you had them, as in, why you would have heard bad about them. Only reason i wouldn't use them is to save money. I'm off to hit a brick wall now then....... Quote Share this post Link to post Share on other sites
s.g 0 Posted February 15, 2006 sorry - forgot the smilies 8) ;) Anyways - if you're just doing a head - probably just as well with std - i'm always pulling engines apart so got arp's - a nice "to have" or necessity if fcukin around with the vr6 - don't really see why you wouldn't use them if you had them, as in, why you would have heard bad about them. Only reason i wouldn't use them is to save money. I'm off to hit a brick wall now then....... :lol: :lol: :brickwall: cheers for that Quote Share this post Link to post Share on other sites
