cymru-corrado
engine swap
with impending engine change on tues which parts are worth getting for general change.
so far i have,
air filter
oil filter
oil cooler and seal
oil
coolant
power steering fluid
gearbox oil
need a few new hoses then some grease and WD40
anything else?
Water pump. Only £25 and worth doing if you are changing the engine as then you know you don't need to do it again.
Water housings including o seals.
Gaskets for everything that is being disconnected/connected.
Jay
water pump on my current lump is only 2 months old so will be using that one,starter motor same,thermostat is newish so to fan switch.
is it worth doing the head gasket with the rest of them?
GSF have listed sump,valve, upper and lower manifold gaskets, these all worth doing then?
I would never split an enigine that runs OK. Could be inviting problems, plus you save several hours and the cost of a gasket kit.
Gavin
