potatonet
adjustable fuel pressure regulator...
who makes a good adjustable FPR with a built in gauge that can go as lower than 25 psi? I need it to go 29 but I want the ability to go lower. IT MUST HAVE A BUILT IN GAUGE, I dont want additional gauges everywhere, I just want it built on.
anything right now helps as I need 2 of them.
Do you mean PSI or BAR. 25 PSI would be no good for fuel injection as far as I am aware.
Summittracing.com have all kinds of gear like that though.
Gavin
2 bar basically is what I will be running 36 lb injectors at, IE 66% duty cycle....
what is the standard corrado fuel injector lb per hour rating? I forget, I think it was 24 lb? these injectors will be running that rating cause they have to? I can run them at 70% which is plenty for fuel injection
thanks for that steve but I need adjustable ones. Ive seen a bosch adjustable one before and I would buy it but I dont know where to get it.
