steveo29 0 Posted March 15, 2006 anyone know the proper idle set up procedure? thanks Quote Share this post Link to post Share on other sites
Henny 0 Posted March 16, 2006 get the car up to temp, (over 50degrees oil and reading on the water gauge) disconnect the blue temp sensor and rev 3 times to over 3K rpm... allow the car to idle again... adjust the idle screw to get the idle to where you want it (should be around 950rpm IIRC) and then rev to over 3K 3 times allowing the engine to drop to idle each time. Re-adjust again as needed. Reconnect the blue temp sensor and your idle should stay the same and be re-set... 8) Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 16, 2006 thanks henny Quote Share this post Link to post Share on other sites
