craigowl 0 Posted April 14, 2006 My car has done 101k and is 11 years old. Belt looks OK. Anyone with a VR6 know of failures? If so what was mileage/age? Would appreciate any relevant info/experience, guys. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted April 14, 2006 i was told by a VW head tech that the replacement schedule for the Serpentine belt is every 60k miles.........mine was changed almost 3 years ago at 53k............ Quote Share this post Link to post Share on other sites
dr_mat 0 Posted April 14, 2006 Sounds like the tensioner will go before your belt, mate .. :) Quote Share this post Link to post Share on other sites
was8v 0 Posted April 14, 2006 Yeah - my tensioner bearing was making a horrific noise at 103k - took a look and the actual bearing had seized leading the the pulley spinning around the bearing and melting away - I got it just in time. My belt was very old and decrepit looking, so I changed it too. Easy job and they are only about £15 or so. Quote Share this post Link to post Share on other sites
martyjmcfly 0 Posted April 14, 2006 I changed the belt last weekend as i noticed it made a dry wispy noise (more noticable under acceleration), almost like a brake pad slightly touching the disc (if you know what i mean). Changed it and hay presto know naff wispy noise. I changed it a couple of years ago with one from GSF. I had a new tensioner fitted couple of months back just for the hell of it. My car is now on 92k and the belt was from VW. Quote Share this post Link to post Share on other sites
craigowl 0 Posted April 15, 2006 Thanks for contributions, guys. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 15, 2006 Yeah, 60k sounds about right for a belt of that length... I very much doubt it's done 101k as I've seen a couple of VR's on 80-90k with what look like original belts and they are very worn/cracked altho this could have been to do with a failing tensioner.. If your not sure of the age and it looks a bit worn then i'd change it for the sake of 15 mins work and also a good time to check the tensioner, better than having the belt snap on a motorway! Quote Share this post Link to post Share on other sites
