MarkGolf
Pressing valve stem seals?
Are you talking about fitting the stem seals to the top of the guides? I have a pair of pliers for removing them, that will also put them back. Failing that, find a socket that they sit nicely in and use that with an extension, to push them down.
Gavin
i used a deep socket too when rebuilding my cylinder head. If you have a gasket kit dont forget to put the cover on the end of the valve when placing them back into the head. it helps protect the seals.
