kasman21 0 Posted April 24, 2006 Hey Guys My rado has become more and more jumpy in first gear recently!!! its really bad, its pulling if i floor it no probs but if i dont floor it, it is really jumpy?? any ideas. I was thinking the timing or maybe a tune up?? If that is the case where should I bring it to sort it?? Im in Lincoln. But i hear stealth would be a good place to go! anyway more local?? thanks all Zak Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted April 24, 2006 start with the basics fella ..... plugs, fuel filter, wires hanging off, ..... nothing worse than paying money to someone for something you could find yerself, once you do the simple stuff then it will help to narrow down the possible reasons for any rough running, ..... it may be useful to list any work that has been done recently as this may have some bearing on your problems you have now, ... and lastly, the search may well be a good source of info, best of luck mr kasman21, Quote Share this post Link to post Share on other sites
kasman21 0 Posted April 24, 2006 i had a check yesterday and everything looked perfect, changed spark plugs and didn't sort it. ill have to double check again tonight and see if im missing something, but if something wasn't entirly right wouldn't the car react the same in every gear??? thanks gaz Quote Share this post Link to post Share on other sites
steveo29 0 Posted April 24, 2006 sounds like a air leak....is the rubber boot split at the throttle body Quote Share this post Link to post Share on other sites
kasman21 0 Posted April 24, 2006 dont think so but i will check all the hoses too. cheers steveo Quote Share this post Link to post Share on other sites
steveo29 0 Posted April 24, 2006 best thing is to yank and twist on all the pipes n hoses while its running....you'l hear a hiss or change of tone if you disturb a split Quote Share this post Link to post Share on other sites
