VR6 South
VR6 and other models - Clocks
1 rpm is 1 rpm regardless of how many cylinders you have, thats crankshaft speed. :-) No idea if they fit though!
There isn't a sensor in there that actually counts revs. The rev counter is connected to the hall-sensor, hence it will see either 4 or 6 pulses per revolution. So yes, it does matter wether you mount a 4-cil or a 6-cil cluster...
