olly elworthy 0 Posted May 2, 2006 heard a roumour on here a while back that you can use audi TT or maybe golf v6 4 motion rear wishbone bushes in teh corrado wishbones as an upgrade as they are made of solid rubber,, anyone have a part no for these!??! :D 8) or can anyone clarify this for me?!?! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 2, 2006 Wouldn't bother unless they're cheap, personally. Use Vibratechnics ones or Whiteline polys. The Whitelines add 0.75 degrees castor into the bargain too :-) Just a recommendation and not gospel ;-) Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 2, 2006 where can you get these whiteline polys? had some powerflex ones in there before but they were golf ones and didnt locate in the horseshoes properly :-(, also what are the effects of running more castor kev?!?! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 2, 2006 Have a word with Julian at http://www.balancemotorsport.co.uk He can get the whiteys....not sure how much they are though, but won't be silly money. Easiest way to describe castor is using bikes! If a bike had little or no castor (the forward angle of the forks), you wouldn't be able to take your hands of the handlebar and keep the bike upright and steering straight. Zero castor is what trolley front wheels do, they flop all over the place, but make it very easy to turn. Adding castor makes the car/bike a lot more stable in a straight line and during cornering, adding castor increases camber, which is what you want. The standard bushes are poop and you lose a lot of camber when flying round bends. The only downside of adding castor is increased steering weight. When you turn the wheel, you are effectively fighting against the road wheel's natural tendency to fall over, so more castor = more lean and more steering weight.....but in practice, the benefits seriously outweigh the negatives. All modern cars are big on castor these days, just makes the car a lot more stable (especially at speed) and turn in better. 0.75 is a modest amount of static castor but it certainly transforms the MK2 platform as the rear bushes have always been it's biggest weakness. Some track day cars run as much as 5 degrees more castor, but they can barely steer the car by the end of a race :-) I'll be trying some whitey's myself at some point..... Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 2, 2006 thnaks kev i will investigate :-) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 2, 2006 I'll be speaking to Julian later actually, so I'll get pricing info ;-) Whiteline are an Australian company by the way and have a brilliant reputation in Subaru circles ;-) Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 2, 2006 excellent i await your reply,, Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 2, 2006 Kev - could you mention 'Magic Camber Bolts' to him - I think Whiteline do them but there catalogue isn't clear... Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted May 2, 2006 Interestingly there is actually a difference in castor between the VR and the 16v/G60 subframe/wishbone setup. Jay Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 2, 2006 Kev - could you mention 'Magic Camber Bolts' to him - I think Whiteline do them but there catalogue isn't clear... these are similar to the old mk1 golf bolts,, allows you to set teh camber allot easier and also allows a bit more room for adjustment i beleive Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 2, 2006 Interestingly there is actually a difference in castor between the VR and the 16v/G60 subframe/wishbone setup. Jay interesting,, what bushes do you run jay? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 2, 2006 Kev - could you mention 'Magic Camber Bolts' to him - I think Whiteline do them but there catalogue isn't clear... these are similar to the old mk1 golf bolts,, allows you to set teh camber allot easier and also allows a bit more room for adjustment i beleive Yeah - It just locks it in place so it can't be 'knocked' out by pot holes etc.. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted May 2, 2006 I run powerflex throughout the front end and OE rear beam bushes. Find it superb with everything else now sorted and brand new. Jay Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 2, 2006 Wasn't aware the 16V/G60 had different castor to the VR, but either way, it's not enough on either platform! It can be done with adjustable top mounts too, but they're expensive and not damped. H&R also do camber bolts for VWs. Never had a problem with the camber slipping myself, but they are very useful all the same! Whiteline also do special shims to give the rear more toe and camber too! I firmly believe that all these tweaks will rejuvinate the C's reputation as one of the best Front wheel drivers around....even compared to modern cars. It's just getting the time to do them all that's the problem! Still waiting for info from my supplier on the bushes... Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted May 2, 2006 VW also do shims for the rear wheels that can be used to adjust camber or toe-in. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted May 3, 2006 I am considering putting a touch more camber on the rear. Are the shims for putting behind the stub axles? jay Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 3, 2006 An aside, but yes it's all true.. VW added extra castor on the VR6 to counter any increases in torque steer due to the extra power relative to the earlier cars. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 3, 2006 An aside, but yes it's all true.. VW added extra castor on the VR6 to counter any increases in torque steer due to the extra power relative to the earlier cars. It's not enough though. +3.25 degrees as standard, needs to be at least 5 degrees imo.....but VW spared a thought for customers with weak arms :lol: Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted May 3, 2006 Could anyone find out the VW part numbers for the shims for me? Cheers Jay Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 4, 2006 It's not enough though. +3.25 degrees as standard, needs to be at least 5 degrees imo.....but VW spared a thought for customers with weak arms :lol: It's got PAS, hasn't it?? Poofs! :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 4, 2006 Jay, use the whiteline ones if you can't coherse your dealer into finding the numbers. Or AP racing can provide stainless shims of varying thicknesses. Mat, yep...still makes the steering heavier though ;-) You could always over drive the PAS with a smaller pulley though.....but you'd need a fluid cooler tho! Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted May 5, 2006 There's already a fluid cooler... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 5, 2006 I know, but that pipe that runs under the radiator that acts as the cooler isn't sufficient with a smaller pulley. Quote Share this post Link to post Share on other sites
