chrishill 0 Posted May 5, 2006 Found this via digg.com, i wasnt reading the fastcar website, honest! First example of a charger with a gearbox, should make for some interesting projects! warning - chav website Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted May 5, 2006 hello chrishill, looks like a marvellous piece of engineering :thumbleft: but i`m getting worried about you and veedub_g60, it appears you may be spending to much time on `chav` sites :shock: :lol: Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted May 5, 2006 What the heck, I thought of that idea a loooong time ago!!! Thought it was a bad one to be honest :-P Quote Share this post Link to post Share on other sites
Jim 2 Posted May 5, 2006 I think a lot of people of have thought of this.. certainly something thats floated through my mind a few times but I always assumed that there were some technical limitations that prevented this from being "do-able" - guess someone finally put pen to paper and sorted it out! :) Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted May 5, 2006 you'd think with CVT already available that they'd just skip geared s/c's Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted May 5, 2006 All i can see is that it needs a tiny pulley banging on, then see what the gearbox makes of it! :twisted: Chris Quote Share this post Link to post Share on other sites
Henny 0 Posted May 5, 2006 Normally, you'd expect up to 50% efficiency out of a supercharger, but this setup promises up to 85%! Erm, isn't the G60 charger around 80% efficient? Quote Share this post Link to post Share on other sites
Toad 0 Posted May 6, 2006 The Superchargers in messerscmitts (those planes from ww2, I can't even be arsed to work out how to spell it), were geared so that at low level the required ammount of boost was available, and when the plane reached high altitudes and the air was thinner, the charger could be sped up to produce the same amount of boost again, if you catch my drift. I guess it meant that the plane could still perform at very high altitudes, but the charger didn't get super stressed when they were just hooning round at sea level. If i remember my history lessons correctly, Post WW1 Germany wasn't allowed to make research into military vehicles such as planes and battle ships etc. However lots of money was pumped into the Grand Prix racing which just happened to use engines which would be ideal for fighter aircraft hence the advanced technology used in the mescherthingumybobs. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted May 6, 2006 Damn those sneaky Huns :lol: Quote Share this post Link to post Share on other sites
chrishill 0 Posted May 6, 2006 If i remember my history lessons correctly, Post WW1 Germany wasn't allowed to make research into military vehicles such as planes and battle ships etc. However lots of money was pumped into the Grand Prix racing which just happened to use engines which would be ideal for fighter aircraft hence the advanced technology used in the mescherthingumybobs. you'd have thought the side mounted machine guns would've given the game away... Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted May 6, 2006 ha ha harrr!! Quote Share this post Link to post Share on other sites
Toad 0 Posted May 6, 2006 If i remember my history lessons correctly, Post WW1 Germany wasn't allowed to make research into military vehicles such as planes and battle ships etc. However lots of money was pumped into the Grand Prix racing which just happened to use engines which would be ideal for fighter aircraft hence the advanced technology used in the mescherthingumybobs. you'd have thought the side mounted machine guns would've given the game away... ROFL!!!! Quote Share this post Link to post Share on other sites
Yandards 0 Posted May 6, 2006 Normally, you'd expect up to 50% efficiency out of a supercharger, but this setup promises up to 85%! Erm, isn't the G60 charger around 80% efficient? A standard 'off the shelf' G lader is quoted at around 65% efficiency from the the brochure I have, but by the time they have been ported and flowed then the efficiency is well up from that figure. It should be possible to calculate the % increase for a porting job but as I don't know of anyone who has had a port carried out and left the standard pulley on it might be difficult :wink: Quote Share this post Link to post Share on other sites
