crazykomo
Engine Temp Gauge doesnt work
First, prove the temperature sender is working/not working by shorting the live feed to earth at the connector. If the temperature gauge rises towards full-scale (don't let it reach full-scale though as it may break) then it's a new temperature sender that's required. If not it's either a wiring fault, or a new gauge/set of clocks needed.
