Riley
Quick G60 coil wiring query
could somebody confirm 110% that im right with the following on a 92 g60...
Green wire on coil=earth?
and
Black wire on coil=ignition live?
just need to know for definate before i try something,cheers.
neil.
Yes.
Signal to ECU actually (pin 25 on the ECU).
Tempest
cheers tempest.ahhh sh!t...so its just earthed through the body then,unless the signal to the ecu is an earth?
i have something to wire up that has three wires:
coil ignition live.
coil negative.
and an earth.
help!
Nope, as that's the ECU's means of controlling the coil, as the G60 no longer has a seperate ignition module (like K-Jets, for example).
It might help to post what you're trying to do, and we might be able to find alternative ways.
Tempest
thanks tempest,pm sent about my little project. :)
just had a thought...
does the rev counter not take a feed from the coil somehow too?
neil.
coil ignition live.
coil negative.
and an earth.
bump,anyone any idea's how i can wire this up?
cheers,neil.
On the 1990-model (like mine) yes. On the 1992 model, no, as the tachometer gets its signal from a separate controller inside the instrument cluster / MFA.
Tempest
ahhh.
feckinell,dont know how i can manage it :(
does the coil (green wire side) have the marking -1 or - ?
