blue95 0 Posted May 23, 2006 Hi just wanted to know if anyone had managed to snap a bleed valve on the front caliper! and what would be the best way to remove it? There is about 2mm left hanging out but the metal is soft, is the best way to drill it out? Thanks Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted May 23, 2006 There is about 2mm left hanging out but the metal is soft, is the best way to drill it out? ........ you could drill it out but be very careful, you need to get a drill that is pretty close to the diameter of the nip so all thats left after drilling it out is a thin sliver that can be pushed in and collapsed then removed with a small screwdriver , might be a good idea to run a tap down the threads after getting it out , you could also try an `easy out` bolt extractor but if it snaps inside the nip then you`ll have a nightmare of a job getting the thing out and may well end up getting another caliper :shock: Quote Share this post Link to post Share on other sites
DanA 0 Posted May 23, 2006 This happened to me a while back on a Mk2 Golf. I snapped an easy out in it and that was that! So as Gaz says, be very careful. Quote Share this post Link to post Share on other sites
blue95 0 Posted May 23, 2006 Can't believe my S**t luck, was only changing the shocks and thought I may as well stick some new pads in and bleed the system aswell. Seen on vagcat you the valve is a seperate item, don't suppose anyone knows the cost? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 23, 2006 they are less than a quid... good excuse to fit G60 calipers tho! Quote Share this post Link to post Share on other sites
madscientist 0 Posted May 24, 2006 I did the same on my mk2 16v so i just got a socket and hammered it over the bit of thread thats left, then it came off. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted May 24, 2006 Did that to mine too, sheared off level with the caliper, so fitted G60 calipers instead of fixing the 16v caliper 8) Quote Share this post Link to post Share on other sites
heliosjim 0 Posted May 25, 2006 happened to me a while back.......... tapped a small hex socket thingy into it and prayed, not much help am i? Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 26, 2006 I always blow torch the caliper before removing bleed nipples. It breaks the grip the threads have. After that its a complete bleed of the system and new fluid all round. Quote Share this post Link to post Share on other sites
