localhost.80 0 Posted May 25, 2006 Questions =================== Trunk Release latch where is it? Power Locks on all models? How do I clean the intercooler? Recommend Type of Gas? Side Fender Lights Relay or Fuse? Number [53] Relay? How come my windows can not be opened at the same time(Power Windows) How do you use the MFA and Rear Wipers? Unpluged Wire Connection under charcoal canister? Head lights does not have a bright light? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 25, 2006 Answers =================== Trunk Release latch where is it? Should be a lock/button to the right of the licence plate on the trunk. Power Locks on all models? Yup, vacuum operated though. How do I clean the intercooler? Ooh, don't know that one. Recommend Type of Gas? Anything above 95RON, though 98RON and higher is preferable. Side Fender Lights Relay or Fuse? Ooh, don't know that one. Number [53] Relay? Ooh, don't know that one. How come my windows can not be opened at the same time(Power Windows) Factory design, stops the circuits being overloaded. How do you use the MFA and Rear Wipers? MFA is the button on the end of the RHS stalk, and the slider on the stalk. Rear wipers - push the RHS stalk towards the dash to start, and again to stop. Unpluged Wire Connection under charcoal canister? Ooh, don't know that one. Head lights does not have a bright light? Because the headlight circuit goes all the way up to the switch and back you get a voltage drop. Search on here for "headlight AND loom" :) Quote Share this post Link to post Share on other sites
localhost.80 0 Posted May 25, 2006 Thanks, also is there a way to open my trunk from inside? Quote Share this post Link to post Share on other sites
vr6storm 0 Posted May 25, 2006 yip............with the key thats in the ign switch :D .................so take key out of ign then walk to back of car,insert key into boot lock turn and voila its opened :?: :lol: Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted May 25, 2006 in other words, no, there isn't an internal trunk release on the Corrado... :) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted May 25, 2006 me bad :clown: ........sorry couldn't resist :D Quote Share this post Link to post Share on other sites
steveo29 0 Posted May 26, 2006 about the gas/petrol USA has a differant rating system to us, put the highest grade in that you can get. Quote Share this post Link to post Share on other sites
