Cylinder_Head
G60 8V Oil Temps Skyrocketing 210 DEGREES
hello, my fellow corrado lovers.
I just bought a Corrado G60 8V SUPERCHARGED(HECK YEAH!)
when I noticed that my oil pressure light was blinking. :cry:
and oil temps raising to 210F degress at idle :shock:.
recently I changed my oil using Mobil 10W30 Semi Syn and with a bosch
premium oil filter and set my timing at the flywheel 6 Degrees with blue temp sensor off. ( rough at idle). Oh and I just installed a P-Flow Cone Filter
and its making very low noise when revved.
So what do you think?
get a multimeter an measure the resistance across two of the connector pins. turn it back until you get about 330 ohms.
no makes no difference, 330ohms is the factory setting for all G60 engines and only affects the CO at idle, after that its done by the lambda probe...
Looks like you have a warm air system on your airbox (we don't have these on UK G60's) the vac pipe operates a flap inside the airbox to let warm air in from the exh. manifold at very low temperatures, so it won't matter, just tape up the vac. pipe from the engine to stop crap getting into it.
I would remove that again, as those type of filters don't filtrate the air enough (compared to the standard paper elements in the air filter box), which is OK for a naturally aspirated engine, but not for the G-Lader (particularly its scroll which rotates at speeds of 13,000 rpm! When little particles that made it through the filter hit the scroll when its doing that speed, your scroll will look like the moon;'s surface after some time, as the material is a soft magnesium-alloy).
Looks like you have a warm air system on your airbox ...the vac pipe operates a flap inside the airbox to let warm air in from the exh. manifold at very low temperatures,
Correct, as my US-G60 also has that flap which is operated by vacuum in the shown hose.
I thought it was 500 Ohms?
Tempest
dont worry too much about a magical ohms setting for the co pot,,
just make sure it is at about 450 - 500 ish and if you want it set up properly you need a co meter or better still an AFR wideband,, its the only way,,
330 ohms is stated in bentley manual I think. I thought 500 ohms was recommended by tuners for Tuned G60's, is this ok for standard engines? Does it really have to be accurate when its just for 'on idle'?
I agree about the airfilter, I run a K&N element in the standard airbox, cone filters suck hot air from the engine bay too.
Can't find that in my Bentley ;-) It just tells you how to set the CO-Pot using a CO-analyser.
Tempest
"I think"
I've read it somewhere, may of been in the Haynes Fuel/Ignition systems book. When I checked mine it was 330 ohms so I left it at that.
