-Neil- 0 Posted June 19, 2006 about every 300-500 miles my water light comes on to tell me its running low. My screw top for the bottle is very stiff at first when un-doing then twists freely then gets grippy and hard to unscrew again before taking it off. But im not sure if it's leaking from there, if i was to replace anything of that part do i need to replace the whole bottle? MY radiator looks like its seen better days but not leaking anywhere. Has anyone got any other ideas what might be causing my water loss? Neil Quote Share this post Link to post Share on other sites
VR6 0 Posted June 19, 2006 Worth changing the expansion tank lid for the sake of a few quid. Can sometimes be the cause for the loss of water. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted June 19, 2006 few quid from the stealers? Quote Share this post Link to post Share on other sites
Spykee 0 Posted June 19, 2006 i have the same problem so would also appreciate some advice on this :) ive done the expansion cap and yes it is a few quid from the dealers :) Quote Share this post Link to post Share on other sites
DUB 0 Posted June 19, 2006 I've had this problem since i bought my C - and the harder i drive it the quicker the water light comes on - was chatting to my mechanic friend and he sugested putting a bottle of RAD-WELD through, for the sake of £3 I thought i'd give it a try, that was a few days ago now and water light's not come on since / i nipped up all the jubblie clips on water pipes while i was there to :wink: Quote Share this post Link to post Share on other sites
steve_16v 0 Posted June 19, 2006 I wouldn't put radweld in my car after reading threads like this http://the-corrado.net/.archive/forum/viewtopic.php?t=32265 Quote Share this post Link to post Share on other sites
DUB 0 Posted June 19, 2006 Fair shout - use it flush it - just waiting for payday! Quote Share this post Link to post Share on other sites
Dec 1 Posted June 20, 2006 I have had a similar problem lately. turns out to be a small leak from just behind the pulley on the waterpump. Worth a look there while the engines running :wink: Quote Share this post Link to post Share on other sites
Spykee 0 Posted June 20, 2006 I have had a similar problem lately. turns out to be a small leak from just behind the pulley on the waterpump. Worth a look there while the engines running :wink: was it an easy fix and did it cost a lot? cheers, Quote Share this post Link to post Share on other sites
Dec 1 Posted June 20, 2006 tbh I haven't fixed it! :oops: The engine is on its last few miles before the turbo transplant, so I'm just keeping a close eye on the water level! A complete water pump is only £22 from vwspares though! :wink:....It's not too bad a job to unbolt it!.....I think there's a "how to" on here somewhere if you do a search! Quote Share this post Link to post Share on other sites
Spykee 0 Posted June 20, 2006 nice one! i will have to check mine out to see if thats where its leaking from.... cheers, Quote Share this post Link to post Share on other sites
Dec 1 Posted June 20, 2006 Here's the link for the complete pump for a non Vr6 C :wink: Pump Pretty good price, I think! Quote Share this post Link to post Share on other sites
Eleanor 0 Posted June 20, 2006 I had the same problem with my Corrado spent loads trying problems thought it might be heater matrix but as no carpets wet couldnt be that but it was the heater exchanger in the left hand side of the car on the back wall just by pass Quote Share this post Link to post Share on other sites
Henny 0 Posted June 21, 2006 if there's a waterleak from just behind the pulley on a 4 cylinder VW engine, it means you need a new waterpump. This leak is caused by an internal seal failing which VW had forseen and actually put a drain into the castings to make the water exit the pump in a controlled manner rather than spraying in all directions! Quote Share this post Link to post Share on other sites
Eleanor 0 Posted June 21, 2006 no I meant I had the problem of loss of water at one point went through the whole process of changing everything as the the chap before and it came down to my heater exchange got a bigger problem with mine that loss of water cant get my head round it Quote Share this post Link to post Share on other sites
