Bally
Bigger Discs with G60 cailpers?? is it possible??
would it be possible to go bigger discs with maybe an adaptor or simlair to run bigger than 280mm?
or am I talking shit :lol:
wished I got brembos when they were cheap now :cry:
OR.... anyone tell me what fitment to get calipers/brakes without going 5stud???
I aint looking to spend stupied money either :lol:
bally - tell me about the brembos mate, nightmare or what.
Can the s2 calipers from g-werks run bigger discs than 280 (or is is 288?) or is that the max?
what kind of power do ppl think + 300mm brakes are needed?
You can get carrier relocation brackets to move the OE calipers further out, which will allow you to run bigger discs. That's about the cheapest way of doing it.
The VR needs bigger brakes in standard form, let alone after adding more power!
Depends really..... you just add power and if you find the brakes aren't up to it, you uprate them accordingly, but the 312 setup is fine for the majority of people.
4 pots will give you a much greater clamping force so you don't need a massive disc to get the required results, around 310mm would be fine.
Didn't the 4 stud ibiza curpa run 312s?
I'm sure the now defunct TSR used to sell the carrier brackets. They used to do packages of carrier brackets, Black diamond discs, braided lines and Ferodo pads. Used to work really well.
Personally I'd go balls out and get some Porsche calipers off ebay, they don't go for mega bucks. Carriers, bells etc etc can all be made to order at places like http://www.bgdevelopments.co.uk for example.
