mtc R32
Suspension Question!! Just a quicky!!
I've been told that Golf VR6 coilovers will fit directly onto a Corrado VR6 ???
Can anyone confirm this
Yes they will *fit* but im sure the weights are slightly differant between the 2 models so they may not be perfect(damping/Spring rates) for your car. It all depends on which company they are manufactured by to wether they call for the same part number between the 2 models.
koni coilovers for the Golf VR6 have the same part number as the Corrado VR6 and G60 IIRC
G60 too???? I would have thought the springs on a VR6 be different to a G60 due to the weights of engines???
from memory they list the same kit for the VR6's AND G60's........tho FK use different kits for the VR6 and G60,even tho obviously the VR6 lump will be heavier,tho with the charger and other bits on the G60 its maybe not such a massive difference in weight
