ngr 0 Posted June 28, 2006 Any of you kind chaps got an R32 loom diagram you could send me? Quote Share this post Link to post Share on other sites
Crasher 3 Posted June 28, 2006 Do you just want the BFH engine wiring diagram or the whole car, the engine alone is 19 pages. Quote Share this post Link to post Share on other sites
ngr 0 Posted June 28, 2006 I need all the relavant info for a conversion so all the engine ecu related stuff to get it running. I have the key and dash as well. So the relavant pages for these would be usefull. Thanks Quote Share this post Link to post Share on other sites
Crasher 3 Posted June 28, 2006 PM me your e-mail address and I will see what I can do. I need the donor cars engine, chassis, gearbox and rear differential numbers Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted June 28, 2006 Coxylaad has a pdf of the BFH/BDE engine loom. I have it somewhere too but can't find it. We both mangaed to get our engines running using this diagram and the help of an electronically minded friend. Quote Share this post Link to post Share on other sites
ngr 0 Posted June 29, 2006 Did you fit the r32 car loom and dash as well or manage to wire it up to the standard corrado guages? I have the dash and key with a compleate loom but would like to remove as much of it as possiable. Any one done this?? Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted June 29, 2006 i could do with the same help,having mine fitted next week Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted June 29, 2006 Mine has been wired into the C clocks, not sure how it was done but I know the Golf clock innards had to be left in for the immobiliser to work. I can try and find out though. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted June 29, 2006 Fit in as much as possible and then you get all the nice toys and full functionality of the MK4. Jay Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted June 29, 2006 Reply from PSI: He used the golf clocks for the immobiliser and spliced the wire off the original clocks. Personally, I wish I'd had the MK4 clocks put in, but may look into that further down the line ;) Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted June 29, 2006 can you fit the mk4 clocks in the corrado dash & binnacle? im going to be using the o2m gearbox,how do i use the corrado speedo with this set up? anyone help? Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted June 29, 2006 can you fit the mk4 clocks in the corrado dash & binnacle? Yep, seen it a couple of times Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted June 29, 2006 any pics? Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted June 30, 2006 http://the-corrado.net/.archive/forum/download.php?id=31683 Quote Share this post Link to post Share on other sites
