Duecenickletreyg60 0 Posted July 3, 2006 i have a 90 g60 and the supercharger is in need of a rebuild, it is leaking oil into my intake and down through the intercooler up into the intake manifold :cry:, i know that bahn brenner rebuilds them for around $700 but being a college student im not floating in cash. i was wondering if anyone knew of a way to run the car without the supercharger, that way it would still be drivable until i have the money for the rebuild? any information would be much apretiated! Quote Share this post Link to post Share on other sites
kongo127 0 Posted July 4, 2006 Yes, it is possible to run your car without the supercharger. All you need it to get a shorter v-belt (don´t know it´s size right now), there are different belt sizes for A/C and non A/C cars. You also need to remove the oil feed hose and block the oil coming from the engine. Re-route your air filter directly to the intercooler. You´ll be impressed by how much power you´ll loose without the supercharger! Keep posting! :) Quote Share this post Link to post Share on other sites
flusted 0 Posted July 4, 2006 Im running mine without charger at the moment and its total pants! i just screwed an oil pressure switch in where the oil feed comes from head and used the smaller belt Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted July 4, 2006 See Here for a how to.. Corrado club Canada. Quote Share this post Link to post Share on other sites
Duecenickletreyg60 0 Posted July 4, 2006 thanks for the help especially the link, you have saved me so much trouble, you guys rock! cheers Quote Share this post Link to post Share on other sites
kongo127 0 Posted June 10, 2007 I took a look at the Canadians Corrado Forum. I found out that the shorter belt to run the car without the supercharger is the 6PK1500. I just wonder if this belt is for cars with or without A/C. My car does not have A/C, so which one is the correct belt? Quote Share this post Link to post Share on other sites
Dubsingh 0 Posted June 13, 2007 if your savy wiv using toosl and dnt mind a bit of graft you can rebuild it yoursel....the main culprit is the oil seals for which you can do a half service yourself...pm me if you want seal sizes Quote Share this post Link to post Share on other sites
