Storm77 0 Posted July 22, 2006 Just fired up the car after sitting on the drive for a week and noticed fuel was running from a black cylinder (looks like a pump with a black pipe running out of it) in front of the fuel tank and o/s wheel. Anyway it leaked for 2 mins , then stopped. Could it be a build up of pressure from the intense heat we've had, and just ejected some on start up? Should I be driving it? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 22, 2006 Sounds like the fuel filter. Get it checked out- never safe to be leaking fuel. Maybe one of the hose ends has perished or something. Worth getting a new one anyway as they're pretty cheap. Mine has been dripping occasionally, mainly because the fixing clamp isn't there anymore so it just swings about on a cable tie. The pipes don't look too good either. My local garage are going to sort it with a new clamp and hot air gun to shrink the hoses snuggly onto the filter. Quote Share this post Link to post Share on other sites
Storm77 0 Posted July 22, 2006 Ah yeah, fuel filter sounds about right. It's not leaking at all now though. Must have been a pressure build up with the recent weather. Need to drive it tonight though :? Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted July 22, 2006 I'm not sure you should ever get fuel leaking from a fuel filter regardless of the weather conditions- If it was my car I would get the the connections renewed (assuming thats the problem) I'm not even sure how any pressure could even build up TBH- the tanks vented so unless there is a one way valve in there somewhere? but even then would it pressure to more than the 4bar pump operating pressure? Quote Share this post Link to post Share on other sites
Storm77 0 Posted July 22, 2006 Very strange - just gave it a good half hour blat - no leaks coming from that area now. Fook knows. :?: Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted July 22, 2006 pressure build up?! I doubt the weather would have any bearing on a fuel pump capable or putting out 3-4 bar. If its leaked it will leak again, get it check out pronto. Quote Share this post Link to post Share on other sites
