Kick Up The Rs 0 Posted August 16, 2006 Right then, My Weitec Ultra GT kit arrived today courtesy of G-Werks. Before I dive in feet first and try and fit it, I have a couple (well quite a few questions) that I’m hoping some of you suspension experts can help me out with! Apologies for the level of questions, as I suspect a lot of this will become apparent when I take it all to bits. Before I get shot down in flames, I’ve done a bit of a search, but I found a couple of contradictory posts on the subject. 1. The rear shocks come with a bag of bits, a lower spring cup (which I believe slides down the shock and locates above the big circlip on the shock body), 3 M10 (ish) nuts, a black cap and a red top-hat type plastic thing (see photo). What are these bits for? 2. Do I need to compress the rear springs to get them off? 3. Do I need the car on it wheels before I finally tighten the rear top / bottom mounts? 4. For the fronts is the correct sequence slacken top mount with deep spanner & Allen key, compress spring, unbolt from carrier? 5. Refitting the reverse of the above? & do I need to locate the start of the new spring in the same position as the old one in the top mount? I Will take some photos and do a little write-up if not done before. Cheers Nick Quote Share this post Link to post Share on other sites
Toad 0 Posted August 16, 2006 1. The rear shocks come with a bag of bits, a lower spring cup (which I believe slides down the shock and locates above the big circlip on the shock body), 3 M10 (ish) nuts, a black cap and a red top-hat type plastic thing (see photo). What are these bits for? I just put new rear shocks on mine, and where all the bits live will become very clear once you take the old ones off. EDIT, hmm, might have spoken a bit too soon, didn't see anything that looked like the red bit before. I did use spring compressors on mine, might get away without, but you'll have them anyway(for the fronts) so you'd just as well use them Quote Share this post Link to post Share on other sites
bcstudent 0 Posted August 16, 2006 I've got a feeling the little red bit locates in the end of the spring...but I can't be sure. It's a few months since I fitted my Weitec kit and the memory has faded a little. I can remember it being pretty obvious when the old stuff came off though. You're risking pain if you try it without spring compressors. It'll be a bugger to assemble the new shock without them too. Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted August 16, 2006 BC How did find the Weitec kit ride-wise? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 16, 2006 I think the red thing sits on top of the damper to stop the bumpstop sucking the oil out? Konis have a similar thing... Quote Share this post Link to post Share on other sites
Walesy 0 Posted August 16, 2006 I'm thinking of getting this kit for my missus's valver, i'll be interested to see the drop and hear what the ride quality is like. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted August 16, 2006 The ride quality is easily as good as it was with the standard shocks. I'd say it's a lot better than you'd expect for a £250 kit. Bear in mind I went for the -30/0 kit (I think), that uses the standard rear springs, as I wanted to lower it as little as possible. As for the red thing...I really can't remember for sure. Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted August 16, 2006 Whilst on the subject of bump stops, which is the best end to shave the 40mm off top or bottom? Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted August 17, 2006 Well looking at the picture of the shock on the side of the box, the black cap fits over the end of the shock. The fronts already have theirs fitted Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted August 23, 2006 Well fitted them last w/e and had the alignment done today. A really easy job, although I had to take the rears off again to reposition the damper circlip to get the desired height. I cannot believe how good the ride quality is, not crashy at all and if anything it feels much better than the original. What amazes me, is the cost - only £65 a corner - just how do they do it??? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 23, 2006 Well fitted them last w/e and had the alignment done today. A really easy job, although I had to take the rears off again to reposition the damper circlip to get the desired height. I cannot believe how good the ride quality is, not crashy at all and if anything it feels much better than the original. What amazes me, is the cost - only £65 a corner - just how do they do it??? Im glad you are pleased with them. We sell lots of these kits now and have not heard any negative feedback on them yet. Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted August 25, 2006 Cheers Darren, Thank Rob for his help re. the my hide puzzle & also mention to him he didn't put any stickers with the invoice!!! Quote Share this post Link to post Share on other sites
